Civil Engineering Association Software Software Product Autodesk Products Autodesk Subscription 2011 MegaPack Multilanguage + Robot Structural Analysis Profess
 niki102
User ID: 8143
Threads: 85
Likes: 2,495 in 189 posts
Given Likes: 845
04-23-2010, 08:49 AM (This post was last modified: 12-14-2010, 11:16 AM by kowheng.)
Robot Structural Analysis Professional
[Image: 32636538905997523817.jpg]
Autodesk Subscription 2011 MegaPack Multilanguage + Robot Structural Analysis Professional
Year: 2010 | Version: 2011
Developer: Autodesk Inc
Platform: Microsoft ® Windows ® XP & Vista & 7
Language: multilingual
Tabletka: Present
Autodesk Subscription 2011 MegaPack Multilanguage - A unique collection of all available today for add-ons for all versions of Autodesk products in 2011, called Subscription Pack's, available to subscribers only licensed Autodesk Inc.
Autodesk Robot Structural Analysis Professional 2011 - Universal application, which is applied BIM (BIM) and supports even very large design models. It allows you to effectively perform complex calculations of building structures from a regional perspective, including payments in accordance with Russian norms and regulations that has been certified by GOSSANDART RUSSIA.
Year: 2010
Version: 2011
Tabletka: Present
Autodesk Subscription 2011 MegaPack Multilanguage:
A list of additions and their descriptions:
Autodesk MatchMover 2011:
Program Autodesk ® MatchMover ™, adopted as an essential tool leading developer of visual effects, allows high-quality conduct tracking trajectory of 3D-camera. With the means at its feature set, designers, visualizers, architects and digital artists are able to extract accurate data 3D-camera and coordinates movement of the results of filming for inserting elements of computer graphics in the scene. MatchMover with features such as automatic tracking coupled with precise manual control needed by professional artists and specialists in visualization projects.
This product is available only to support the type Up & Ready.
Autodesk is providing support Up & Ready just for ancillary products within thirty (30) days after registration. Learn more about Up & Ready, see page
Support in different forms, including, in particular, over the Internet or by telephone, regardless of user rights to other forms of support in accordance with the subscription, to which the auxiliary product is not available.
Autodesk Robot Structural Analysis Professional 2011:
Thanks to the integrated design standards in the calculation of structures Autodesk Robot Structural Analysis Professional takes a few minutes. This solution for the design of building structures has broad capabilities for simple and complicated calculation mesh finite element analysis, work with steel and reinforced concrete structures. It is easy to fit in with other Autodesk's structural design, as well as third-party products.
Features:
Autodesk ® Robot ™ Structural Analysis Professional provides an effective means of calculation and automatic partitioning into finite elements. The program allows structural engineers quickly simulate and calculate the complex load.
Key Features Autodesk Robot Structural Analysis Professional:
- Two-way link with Autodesk Revit Structure;
- Enhanced partitioning into finite elements;
- Opportunities of calculations and analysis;
- Ultra-modern means of calculating the dynamic loads;
- Customizable display the results of calculations;
- Availability of localized versions and support of various units of measurement;
- Adaptation to the state standards and design standards of specific countries;
- Settlements in sootverstvie with Russian norms and regulations that has been certified by GOSSANDART RUSSIA
- Integrated design solutions for the calculation of reinforced concrete and steel structures;
- A single working process calculation of building structures and production of working drawings;
- Open and flexible API-Interface.
Features:
Two-way communication with Autodesk Revit Structure:
Revit ® Extensions module allows unrestricted import and export of model structures between Autodesk ® Robot ™ Structural Analysis Professional and Autodesk ® Revit ® Structure. With bi-directional associativity calculations and design data are updated within the entire information model that promotes production of a coherent documentation.
Enhanced partitioning into finite elements:
Effective methods of forming a network simplify the work of structural engineers with even the most complex models. Automatic partitioning into finite elements and parameterization grid cells can be made separately for each panel, which has a positive effect on the accuracy of calculations.
Extensive calculations and analysis:
Any design requires a careful study of linear and nonlinear loads actual. The program provides a simple and effective analysis of various non-linear loads - for example, pi-delta effect (vertical load for horizontal movements), tension / compression support moments and hinges plasticity. Features also allow to calculate the structural response to dynamic loading: the frequency harmonics, seismic events, etc.
Ultra-modern means of calculating the dynamic loads:
Ultra-modern means of calculating the dynamic loads can be applied to designs of any size. Estimated algorithms Autodesk Robot Structural Analysis Professional designed and optimized for quad and multicore processors. This allows structural engineers to obtain accurate results in minutes.
Customizable display the results of calculations:
Autodesk Robot Structural Analysis Professional is a flexible settlement decision. The results, including visualization and baseline data are displayed in the form:
- Tables, making it easier to filter and organize data;
- Bar charts;
- Sections of the shell structure;
- Illustrated color schemes;
- Schematic image loads on the entire structure when subjected to beams and columns;
- Schematic image loads on the elements and full-shell structures in selected areas.
Text documents can be stored in a file format Microsoft ® Word ® or HTML. Tables
The presence of localized versions and support of various units of measurement:
There are versions of Autodesk Robot Structural Analysis Professional English, French, Romanian, Spanish, niderlandskom, Russian, Polish, Chinese and Japanese languages. You can make calculations for building structures in one language, and their results displayed on another. In one model design can be combined metric and imperial units of measurement.
Adapting to the standards and design standards of specific countries:
Autodesk Robot Structural Analysis Professional contains more than 60 databases of building elements and materials, appropriate design standards and regulations of different countries. Thanks to a predetermined array includes 70 design standards, structural engineers can work with a single model, using different units of measurement. Autodesk Robot Structural Analysis Professional allows vyplnyat calculations sootverstvie with Russian norms and regulations that has been certified by GOSSANDART RUSSIA.
Integrated design solutions for the calculation of reinforced concrete and steel structures:
Autodesk Robot Structural Analysis Professional contains features that correspond to more than 40 standards of design of steel structures and 30 of the rules of design of reinforced concrete structures adopted in different countries.
Unified workflow calculation of building structures and production of working drawings:
After creating the model and the calculation of building structures in Autodesk Robot Structural Analysis Professional, you can easily transfer model and the results in AutoCAD ® Structural Detailing for the production of detailed drawings.
Open and flexible API-Interface:
Using the technology of Microsoft COM (Component Object Model), Autodesk Robot Structural Analysis Professional offers an open and flexible API (application programming interface). With it, you can:
- Establish links between Autodesk Robot Structural Analysis Professional and external programs, such as Microsoft ® Excel, Microsoft ® Word and AutoCAD ®;
- Retrieve the results of calculations performed in Autodesk Robot Structural Analysis Professional;
- To create applications for further processing - such as special codified calculations for steel, concrete, wood and aluminum construction;
- Create parametric design in Autodesk Robot Structural Analysis Professional.
MD5 CRC:
RSAPRO2011.iso - f75a17e5d588532cc518a3f7f8f0b6af
[Image: 31127373025209132163.jpg]
[Image: 61066582132563522980.jpg]
[Image: 69270500720676326600.jpg]
[-] The following 22 users Like niki102's post:22 users Like niki102's post
  • jjmtz, Kerry, belkhedim, Panjack39, oreslaw, sasan73, falconado, cve_jule, henrycv, leonelmariana, Veggeta, hectorru, Adam Smith, Struc-Con, kaiboool, ChisTeam, pepape, gacella, emekajohn, 07ANTONIO, hazus, rezart
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,128
Likes: 30,986 in 4,091 posts
Given Likes: 612
04-23-2010, 09:22 AM
The actual mega pack includes :
Autodesk Revit DB Link 2011
Autodesk Revit Model Review 2011
Batch Print for Autodesk Revit 2011
Design Spreadsheets for Autodesk Robot Structural Analysis 2011
DIALux Plug-in for AutoCAD MEP 2011
Globe Link for Autodesk Revit 2011
Revit Extensions for Autodesk Revit Architecture 2011
Revit Extensions for Autodesk Revit MEP 2011
Revit Extensions for Autodesk Revit Structure 2011
Robot Extensions for Autodesk Robot Structural Analysis 2011
Space Naming Utility for Autodesk Revit MEP 2011
Worksharing Monitor for Autodesk Revit 2011
You specify only the first title. Is the same ?
Your transparent link (don't warned for it) is dead.
[-] The following 5 users Like BennyP's post:5 users Like BennyP's post
  • YaqubMughal, kaykaysoft, ruwan75, emekajohn, oanm2000
 BennyP
User ID: 842
Threads: 1,128
Given Likes: 612
04-23-2010, 12:18 PM
Meanwhile you can use the link for the torrent file. Downloaded (using Vuze) but checked only the Robot related from the list above.
[-] The following 11 users Like BennyP's post:11 users Like BennyP's post
  • jjmtz, niki102, kaykaysoft, jcbv, falconado, ruwan75, mig21, cve_jule, plancoet, rezart, oanm2000
 ceetee
User ID: 25757
Threads: 0
Likes: 5 in 2 posts
Given Likes: 4
08-02-2010, 08:08 PM (This post was last modified: 08-03-2010, 01:50 AM by kowheng.)
Took the better part of 2 days but was worth it
Revit Extensions for Autodesk Robot Structural Analysis 2011
[-] The following 4 users Like ceetee's post:4 users Like ceetee's post
  • Struc-Con, spyridoula, oreslaw, oanm2000
 raslanuf
User ID: 5829
Threads: 0
Likes: 6 in 1 posts
Given Likes: 3
09-05-2010, 09:02 AM (This post was last modified: 09-05-2010, 10:31 AM by kamran.)
Autodesk Storm and Sanitary Analysis 2011 Extension-ONLY
The Autodesk® Storm and Sanitary Analysis 2011 Extension is a comprehensive, hydrodynamic hydrology and hydraulic analysis application for planning and designing urban drainage systems, storm sewers including highway drainage systems, and sanitary sewers.
With this extension, engineers and planners using AutoCAD® Civil 3D® 2011 and/or AutoCAD® Map 3D 2011 software can analyze both simple and complex networks including:
- Inlets and catch basins
- Detention ponds and outlet structures
- Interconnected ponds
- Flow dividers, standpipes, weirs, and orifices
- Pumps and lift stations
- Manholes and junctions
- Rivers, streams, and ditches
- Culverts and bridges
Some of the key features and benefits of the Autodesk Storm and Sanitary Analysis 2011 Extension are:
- Bi-directional exchange of data with AutoCAD Map 3D and AutoCAD Civil 3D
- No limitation on the number of pipes or elements you can include in your model
- Widely-accepted SWMM analysis engine
- Broad range of hydrologic methods
- Stormwater BMPs
- Detention pond design
- Stormwater quality modeling
- Customizable report generation for regulatory review
- GIS interoperability
- Work in either US or Metric (SI) units
Moderator Notes:
Please use "NEW REPLY" button next time. You may be warned for spamming if you kept replying with "REPLY" button (quoted text without good reason).
sorry forget part 2 of the file:
[-] The following 6 users Like raslanuf's post:6 users Like raslanuf's post
  • Dell_Brett, kamran, Veggeta, oreslaw, rezart, oanm2000
 sanitkku
User ID: 118
Threads: 1
Likes: 2 in 1 posts
Given Likes: 0
02-28-2012, 07:24 PM
all download link were delete!!!
please post new link for download it.
thank you.
  Autodesk Robot 2026 rami1976 0 3,045 05-27-2025, 09:10 PM
  Autodesk Robot Structural Analysis Professional 2024 (x64) Multilanguage TAFATNEB 1 12,178 04-16-2023, 09:52 AM
  Autodesk Navisworks Simulate 2024 (x64) Multilanguage TAFATNEB 1 4,794 04-03-2023, 04:08 PM
Last Post: cargadory2k
  Autodesk 3DS MAX 2022 (x64) Multilanguage BennyP 2 8,374 08-27-2022, 02:21 PM
Last Post: alireza55
  Autodesk Revit LT 2021.1 (x64) Multilanguage BennyP 1 4,965 02-22-2021, 03:40 PM
  Autodesk Robot Structural analysis Professional 2021 rami1976 4 9,967 04-18-2020, 11:52 PM
Last Post: rigid_joint
  Autodesk Robot 2020 structural analysis professional rami1976 2 7,293 04-26-2019, 03:43 AM
