Civil Engineering Association Software Software Product Autodesk Products AUTODESK AUTOCAD REVIT MEP SUITE V2011
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,128
Likes: 30,985 in 4,091 posts
Given Likes: 612
04-20-2010, 04:48 AM (This post was last modified: 04-21-2010, 05:46 PM by BennyP.)
WIN32-WIN64 | Fomat: ISO | 3DVD |
AutoCAD® Revit® MEP Suite building design software combines Autodesk® Revit® MEP building information modeling (BIM) software and AutoCAD® MEP software to offer a comprehensive energy-efficient building solution for mechanical, electrical, and plumbing (MEP) engineers, designers, and drafters.
Release info:
DVD1: AutoCad Revit MEP
DVD2: AutoCad MEP for Revit Suite 32Bit
DVD3: AutoCad MEP for Revit Suite 64Bit
Check install.txt on DVD1
Downloaded from Rapidshare and installed. In the proccess of installation for installing the content you need to be connected to internet and you need many time for downloading. You can stop this download and to renew it later when running the software.
The bad news - DVD1 need a single layer DVD but the 2 and 3 need double layer for burning.
The good news - 2 and 3 are the same as Autocad MEP so if you downloaded before you don't need them (for me is too late).
[Image: 97701851716883678600.gif]
[Image: 46969768751578759019.gif]
[-] The following 8 users Like BennyP's post:8 users Like BennyP's post
  • dfense, Dell_Brett, sasan73, kica148, kamran, flyboy777, DamaD, ha893459
 kamran
Senior Member
User ID: 91
Threads: 61
Likes: 1,777 in 176 posts
Given Likes: 1299
05-24-2010, 08:10 AM
(04-20-2010, 04:48 AM)BennyP Wrote: Downloaded from Rapidshare and installed. In the proccess of installation for installing the content you need to be connected to internet and you need many time for downloading. You can stop this download and to renew it later when running the software.
Thanks dear BennyP ,
here Libraries links:
after download these files & Revit MEP Files that given by BennyP
copy Revit MEP Files (burn or mount) to your hard and creat folder
ContentAll
and copy the files you downloaded to this folder
ENULookupTables.cab
IES.cab
SamplesRME.cab
then creat next folder
ContentENU
and copy the rest of files to this folder
Open RevitInstall.ini file in installation DVD and change line #5 from
to
now you run setup.exe ! :clap:
by kamran ! ! !
Kamran via HP :)
[-] The following 3 users Like kamran's post:3 users Like kamran's post
  • Dell_Brett, DamaD, mondra.12345
  AutoRebar for Autodesk AutoCAD poolmand 1 11,784 08-18-2025, 09:58 AM
  Autodesk AutoCAD Civil 3D 2025 poolmand 2 5,413 12-02-2024, 01:09 PM
  Autodesk AutoCAD Plant 3D 2022 (x64) Pre-Cracked BennyP 1 10,138 10-27-2023, 04:10 PM
Last Post: Dalvisahi014
  Autodesk AutoCAD 2022 (x64) BennyP 5 13,224 03-29-2022, 11:33 AM
Last Post: Arigato
  Autodesk AutoCAD Civil 3D 2022 poolmand 2 11,091 03-13-2022, 03:04 PM
Last Post: pilitro
  Autodesk Revit 2022 poolmand 9 11,294 11-16-2021, 08:14 AM
  Autodesk AutoCAD Raster Design 2019 BennyP 5 10,340 09-22-2021, 09:07 AM
