Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem ETABS
ETABS
 juice
User ID: 108
Threads: 8
Likes: 362 in 68 posts
Given Likes: 176
Points:4,193 EP
01-31-2009, 09:50 PM
To ETABS newbies, always check your "GLOBAL FORCE BALANCE RELATIVE ERRORS" in Last Analysis Run Log.
Don't get too excited at once on the output. ;)
[-] The following 12 users Like juice's post:12 users Like juice's post
  • alexcv, alexcv, Grunf, Grunf, levanduy, levanduy, Yasir, Yasir, blackjack, zrilek, deadlord, stigtg
 Yasir
User ID: 206
Threads: 17
Likes: 181 in 29 posts
Given Likes: 892
Points:3,445 EP
02-01-2009, 12:20 AM
heyy juice... please explain.. how to check it... thanks in advance
 juice
User ID: 108
Threads: 8
Given Likes: 176
Points:4,193 EP
02-01-2009, 06:45 AM
Hi Yasir, go to File menu after analysis is complete, click on Last Analysis Log, and check the text file for GLOBAL FORCE... The errors are in percentage.
[-] The following 2 users Like juice's post:2 users Like juice's post
  • Yasir, Yasir
 aslam
Abu Dhabi
User ID: 64
Threads: 330
Likes: 7,707 in 755 posts
Given Likes: 2168
Points:42,050 EP
02-02-2009, 06:37 AM
hello, Juice, Yasir,
Plz correct (guide) me if i am wrong :
(1) Two way slabs shall be modelled as SHELL and need meshing
(2) One way slabs shall be modelled as MEMBRANE and NO need meshing
(3) Stiffnes modifiers for beams,columns,walls,slabs needed on when nonlinear
analysis not performed.
(4) ETABS only gives area of reinforcement for columns & beams (section to be
designed & not to be checked) and not the dia of bars and its arrangement.
(5) for beam we get steel requirement at column face, mid span only and not at
other sections of beam. How to decide upto which distance extra top steel at
support and extra stirrups at end required?
 juice
User ID: 108
Threads: 8
Given Likes: 176
Points:4,193 EP
02-02-2009, 08:05 AM (This post was last modified: 02-06-2009, 12:57 AM by juice.)
(02-02-2009, 06:37 AM)aslam Wrote: hello, Juice, Yasir,
Hi Aslam,
Answers to your queries:
1) Two way slabs - model these as membrane; preferably with meshing
2) One way slabs - yes; as membrane; preferably with meshing
3) modify your beam and column stiffness; if you're doing linear analysis
4) ETABS will give you the required area of reinforcements
5) Remember ETABS is not a black box for design; use your engineering judgement -- we're supposed to be structural engineers not encoders ;)
I hope these help.
juice
[-] The following 5 users Like juice's post:5 users Like juice's post
  • Grunf, Grunf, mig21, levanduy, narendra
 aslam
Abu Dhabi
User ID: 64
Threads: 330
Given Likes: 2168
Points:42,050 EP
02-02-2009, 04:42 PM (This post was last modified: 02-06-2009, 12:58 AM by juice.)
Thanx Juice,
Can u suggest me most common values of stiffness modifiers for columns, beams, walls etc.
I read somewhere that two slabs shall be modeled as shell to have both Membrane(in plane forces) +Plate (bending) behavior. If u model it as memebrane there will not be any bending.
Plz clearify.
Hi Aslam,
I hope these help.
juice
 yucapareja
User ID: 8
Threads: 68
Likes: 870 in 135 posts
Given Likes: 381
Points:9,137 EP
02-02-2009, 04:53 PM (This post was last modified: 02-06-2009, 12:56 AM by juice.)
Hi Aslam,
I hope these help.
juice
Hi everyone
1) Agree
2) Agree
3) not really sure about that
4) For beams ETABS will give you the required area of reinforments, but for columns also check the reinforments that you asign for the column.
5) Agree
Bye..
yucapareja
 juice
User ID: 108
Threads: 8
Given Likes: 176
Points:4,193 EP
02-02-2009, 09:18 PM
1. Best source of recommended values - the concrete design code used in your country
2. Paulay and Priestly's book
3. Charles Salmon's book on reinforced concrete
4. ACI 318-08 (recently posted in the forum), etc.
If you intend to design your slab for needing bending, go for SAFE instead of ETABS. Membrane - no out-of-plane stiffness; load distribution to your supporting beams will be roughly similar to how you would distribute the loads with 45deg angle for tributary area.
[-] The following 3 users Like juice's post:3 users Like juice's post
  • Grunf, Grunf, deadlord
 aslam
Abu Dhabi
User ID: 64
Threads: 330
Given Likes: 2168
Points:42,050 EP
02-05-2009, 01:18 PM
Hello everybody,
Is it possible to define & design Boundary element (size larger than regular wall) in shear wall in etabs?
 juice
User ID: 108
Threads: 8
Given Likes: 176
Points:4,193 EP
#10
02-05-2009, 11:43 PM (This post was last modified: 02-06-2009, 06:05 AM by juice.)
(02-05-2009, 01:18 PM)aslam Wrote: Hello everybody,
If the intention is to model boundary elements that are thicker than the wall; then the answer is yes, it is possible.
It will be nice if other members of the forum could give aslam some guidance on how to do this; i.e., share your ETABS knowledge.
  • Grunf, Grunf
Users browsing this thread: 6 Guest(s)
Pages (12): 1 2 3 4 5 6 7 8 9 10 … 12 Next »
