Civil Engineering Association Various Free Discussion Etabs 18.0.2, Sap2000 V21.1, Bridge v21.1.0, Detail V18.0
 faros3000
Senior Member
User ID: 61
Threads: 24
Likes: 1,265 in 175 posts
Given Likes: 1793
Points:15,551 EP
10-04-2019, 05:50 PM
CivilEA users, please beware that the latest keygen posted for the following software
CSI ETABS 18.0.2
CSI SAP2000 V21.1
CSI Bridge v21.1.0
CSi Detail V18.0
clearly states that:
"NOTE: program has to be ONLINE (has access to the internet) otherwise program will not even start."
As CSI is now actively pursuing unlicensed users of its software, connecting the software online is a highly risky bet, unless you are in a country that does not have much cooperation with intellectual property enforcement agencies/organisms.
Information is not knowledge.
Albert Einstein
[-] The following 4 users Like faros3000's post:4 users Like faros3000's post
  • versiondemo, cargadory2k, temp1366, ascetic19
 temp1366
Senior Member
User ID: 85519
Threads: 80
Likes: 1,544 in 165 posts
Given Likes: 736
Points:12,414 EP
10-05-2019, 04:56 AM
As far as I've tested, ETABS & DETAIL run perfectly fine without internet access.
As for collecting remote data, it is illegal, unless with explicit permission from user. Maybe something is mentioned in EULA.
[-] The following 2 users Like temp1366's post:2 users Like temp1366's post
  • faros3000, techno
 versiondemo
User ID: 6052
Threads: 4
Likes: 24 in 19 posts
Given Likes: 716
Points:1,616 EP
10-05-2019, 11:13 AM (This post was last modified: 10-05-2019, 11:15 AM by versiondemo.)
I know the Dassault Systems policy with SolidWorks and they spy the use of cracked versions. With the main program, they install a software that sends the IP, Computer name, time of usage, serial number, etc... And they use this information to contact the "fraudulent" user offering him two posibilities:
a) Buy a full license of the program.
b) A demand for an important amount of money that they calculate based on the time that the user has been using the illegal software.
The express consent of the user is taken for granted when you accept the conditions to install the program, something we rarely read. So be aware on using cracked versions with internet access.
[-] The following 1 user Likes versiondemo's post:1 user Likes versiondemo's post
  • faros3000
 ralarcon
User ID: 2278
Threads: 7
Likes: 154 in 8 posts
Given Likes: 178
Points:998 EP
10-05-2019, 04:52 PM
Can you use any software that prevents programs connect to the internet?
 faros3000
Senior Member
User ID: 61
Threads: 24
Given Likes: 1793
Points:15,551 EP
10-05-2019, 07:30 PM (This post was last modified: 10-05-2019, 07:35 PM by faros3000.)
(10-05-2019, 04:56 AM)temp1366 Wrote: As far as I've tested, ETABS & DETAIL run perfectly fine without internet access.
Thanks for you comment.  Did you install it offline also, or needed to be online?
(10-05-2019, 04:56 AM)temp1366 Wrote: As for collecting remote data, it is illegal, unless with explicit permission from user. Maybe something is mentioned in EULA.
Not for software companies, nor for any american company in any case.  I mean, it might be illegal, but as they have the power to do so, they do.  You just don´t know where they got your data, they just sue when they know who and where you are.  (Think about Google).
(10-05-2019, 11:13 AM)versiondemo Wrote: I know the Dassault Systems policy with SolidWorks and they spy the use of cracked versions. With the main program, they install a software that sends the IP, Computer name, time of usage, serial number, etc...
Same policy used now by CSI, Autodesk and Tekla. And that´s how I got caught !
Albert Einstein
[-] The following 3 users Like faros3000's post:3 users Like faros3000's post
  • temp1366, versiondemo, ascetic19
 temp1366
Senior Member
User ID: 85519
Threads: 80
Given Likes: 736
Points:12,414 EP
10-05-2019, 07:55 PM
(10-05-2019, 07:30 PM)faros3000 Wrote: Thanks for you comment.  Did you install it offline also, or needed to be online?
on my notebook i installed it with active internet connection and on PC in offline because my pc is not connected to any network (Local Lan or internet)
On both of the ETABS working without any problem (seemingly)
(10-05-2019, 07:30 PM)faros3000 Wrote: Not for software companies, nor for any american company in any case.  I mean, it might be illegal, but as they have the power to do so, they do.  You just don´t know where they got your data, they just sue when they know who and where you are.  (Think about Google).
That is a huge problem and i don't know how it can be fixed. but as for me, I'm blocking every app (even does obtained legally) from accessing internet.
[-] The following 5 users Like temp1366's post:5 users Like temp1366's post
  • faros3000, versiondemo, concreteok, ascetic19, kirankumarklk
 amindoxiti
User ID: 86739
Threads: 203
Likes: 8,341 in 584 posts
Given Likes: 2616
Points:35,180 EP
10-08-2019, 10:48 AM
Hello,
I installed both Etabs 18.0.2 and sap2000 V21.1 without an active internet connection. Although I disabled "native image generation", they are not slow at all. Finally, I performed a nonlinear time history analysis, pushover analysis, and design of a 2D steel frame without any problem. They sound OK.
Do not worry about your difficulties in Mathematics, I can assure you mine are still greater.  -Albert Einstein
[-] The following 10 users Like amindoxiti's post:10 users Like amindoxiti's post
  • promo8, Nita1391, faros3000, malc, temp1366, concreteok, cace-01, kirankumarklk, ascetic19, Dell_Brett
