Journal of Engineering Mechanics - Papers
Current time: 07-19-2018, 06:25 PM
Author: lisine
Replies 3
Views 2239
Journal of Engineering Mechanics - Requested papers
Strength of Stiffened Flanges in Horizontally Curved Box Girders
Author: Choi Byung H.,Yoo Chai H. | Size: 0.3 MB | Format: PDF | Quality: Original preprint |
Publisher: Journal of Engineering Mechanics; Vol. 131, Issue 2 | Year: Feb2005 | pages: p167-176, 10p.
Abstract:
Longitudinal stiffeners are often attached to increase the buckling strength of thin-walled box girder flanges. The minimum required rigidity for longitudinal stiffeners for curved box girder flanges is given by the AASHTO “Guide specifications for horizontally curved steel girder highway bridges.” However, this requirement is simply adopted from the current AASHTO specifications for straight stiffened flanges. The validity of this requirement has been questioned in a series of recent studies. The effect of important design parameters on the minimum required stiffener rigidity is investigated numerically in this study by examining the prebuckling stress distribution and elastic and inelastic buckling stresses of horizontally curved stiffened flanges. In order to characterize and quantify the analytically collected data, a series of parametric studies were performed. A new equation for the minimum required rigidity for the longitudinal stiffeners is derived from regression analyses. Through the evaluation of a few selected case studies and a design example, the validity and reliability of the proposed new equation is demonstrated.
[-] The following 11 users say Thank You to lisine for this post:
  • kowheng, farahshaheen47, chrono146, ingchio, zrilek, sodapas, Dell_Brett, slowet, NBZ1400, blaze, shadabg
Identification of the Soil–Structure Interaction System Using Earthquake Response Data
Author: Jun-Seong Choi, Jong-Seh Lee, Chung-Bang Yun | Size: 0.2 MB | Format: PDF | Quality: Original preprint | Publisher: Journal of Engineering Mechanics; Vol. 130 Issue 7 | Year: July 2004 | pages: p753-761, 9p | ISBN: 07339399
This paper demonstrates how system identification techniques can be successfully applied to a soil–structure interaction system using the earthquake response data. The parameters identified are the shear moduli of several near-field soil regions and Young’s moduli of the shell sections of the structure. The soil–structure interaction system is modeled by the finite element method combined with the infinite element formulation for the unbounded layered soil medium. The simulated earthquake responses using the identified parameters are shown to be in excellent agreement with the observed response data. Prediction of the responses is also carried out for a larger earthquake event using the identified parameters as the initial properties in the equivalent linearization procedure. It has been found that the predicted responses are also compared very well with the measured responses.
  • Dell_Brett, malc, Grunf, cace-01, zrilek, kowheng, gulilero, igor1234, mary, sodapas, shadabg
Failure and Dilatancy Properties of Sand at Relatively Low Stresses
Author: Laurent Lancelot; Isam Shahrour; and Marwan Al Mahmoud | Size: 0.89 MB | Format: PDF | Quality: Original preprint | Publisher: Journal of Engineering Mechanics, Vol. 132 Issue 12 | Year: Dec2006 | pages: 1396-1399.
[-] The following 5 users say Thank You to lisine for this post:
  • freequo, Dell_Brett, kowheng, shadabg, sodapas
Application of the Viscoelastic Continuum Damage Model to the Indirect Tension Test at a Single Temperature
Author: Jaeseung Kim; West, Randy C. | Size: 0.37 MB | Format: PDF | Quality: Original preprint | Publisher: Journal of Engineering Mechanics. Apr2010, Vol. 136 Issue 4, | pages: p496-505.
[Image: 31451484815391222719.jpg]
[-] The following 8 users say Thank You to lisine for this post:
  • Dell_Brett, Mohammad6299, sodapas, kowheng, shadabg, shalaka, tluc, malc
Journal of Materials in Civil Engineering - Papers lisine 3 2,631 06-28-2013, 10:24 AM
Journal of Structural Engineering - Papers lisine 10 7,135 06-07-2013, 07:41 AM
Journal Engineering Structures - Papers lisine 6 4,248 04-10-2013, 08:01 AM
Journal of Constructional Steel Research - Papers lisine 4 2,815 03-23-2013, 01:01 PM
Last Post: ssobhan
International Journal of Geomechanics - Requested papers lisine 3 2,419 02-26-2013, 09:47 AM
