Civil Engineering Association eBooks Journals, Papers and Presentations Journal of Constructional Steel Research - Papers
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,708 in 1,305 posts
Given Likes: 4621
11-08-2012, 04:04 PM
Journal of Constructional Steel Research - Requested papers
Numerical analyses of steel beam–column joints subjected to catenary action
Author: Bo Yang, Kang Hai Tan | Size: 2.63 MB | Format: PDF | Quality: Original preprint | Publisher: Journal of Constructional Steel Research, Volume 70 | Year: March 2012 | pages: 1–11 | ISBN: 0143-974X
[Image: 17473494825532818403.jpg]
The finite element analysis of the ultimate behavior of thin-walled carbon steel bolted connections
Author: TaeSoo Kima, HaYoung Jeong, Taejun Cho | Size: 8.6 MB | Format: PDF | Quality: Original preprint | Publisher: Journal of Constructional Steel Research Volume 67, Issue 7 | Year: July 2011 | pages: 1086–1095
[Image: 76285949786744434948.jpg]
Finite element analysis and experimental study on high strength bolted friction grip connections in steel bridges
Author: Yong-hui Huanga, Rong-hui Wang, Jin-hua Zou, Quan Gan | Size: 8.6 MB | Format: PDF | Quality: Original preprint | Publisher: Journal of Constructional Steel Research Volume 66, Issue 6 | Year: June 2010 | pages: 803–815
[Image: 00119547308285802314.jpg]
All three papers
[-] The following 12 users Like lisine's post:12 users Like lisine's post
  • malc, kowheng, tomtumx, malee, marion33, zrilek, eliseo.as, Dell_Brett, slowet, sodapas, jcbv, blaze
 lisine
Vanuatu
User ID: 17927
Threads: 272
Given Likes: 4621
02-08-2013, 08:39 AM (This post was last modified: 02-08-2013, 08:39 AM by lisine.)
Progressive collapse analysis of high-rise building with 3-D finite element modeling method
Author: Feng Fu | Size: 9.54 MB | Format: PDF | Quality: Original preprint | Publisher: Journal of Constructional Steel Research Volume 65, Issue 6 | Year: June 2009 | pages: 1269-1278
[Image: 98828430096578213522.jpg]
[-] The following 8 users Like lisine's post:8 users Like lisine's post
  • Dell_Brett, devilmaycry, slowet, malc, kowheng, sodapas, jcbv, blaze
 lisine
Vanuatu
User ID: 17927
Threads: 272
Given Likes: 4621
02-14-2013, 10:38 AM
Evaluating response modification factors of concentrically braced steel frames
Author: Mussa Mahmoudi, Mahdi Zaree | Size: 1.29 MB | Format: PDF | Quality: Original preprint | Publisher: Journal of Constructional Steel Research, Volume 66, Issue 10 | Year: October 2010 | pages: 1196–1204
[Image: 17445825687579948075.jpg]
[-] The following 6 users Like lisine's post:6 users Like lisine's post
  • kowheng, malc, sodapas, Dell_Brett, jcbv, blaze
 arshiakh
User ID: 37777
Threads: 100
Likes: 3,224 in 617 posts
Given Likes: 214
03-23-2013, 11:54 AM
Effect of Weld Details on the Ductility of Steel Column Baseplate Connections
Author: A.T. Myers, A.M. Kanvinde , G.G. Deierlein , B.V. Fell | Size: 1.5 MB | Format: PDF | Quality: Unspecified | Publisher: Journal of Constructional Steel Research jo | Year: 2009 | pages: 13661373 | ISBN: 0143-974X
[Image: 97517550419715621555.jpg]
Results from six two-thirds scale tests on moment-resisting steel column base plates are presented. The test specimens incorporate Complete Joint Penetration (CJP) and Partial Joint Penetration (PJP) weld details between the column and the base plate. The test data indicate that both details are resilient to fracture and sustain inelastic column hinging to story drift ratios of 6%9%, which exceeds the typical acceptance criteria of 4% drift ratio for seismically detailed special moment frames. In five of the six tests, fractures initiated in the Heat Affected Zone (HAZ) at the fusion line between the weld and column flange. In the sixth test, fractures initiated at the inside face of the column flange at the upper edge of the weld access hole of the CJP weld detail. Contrary to the initial expectations, the specimens with the PJP welds exhibited higher displacement ductility than those with CJP welds. This is attributed to the fillet reinforcing that strengthens the PJP welds and enables them to sustain stresses and strains necessary to fully develop yielding in the column flanges.
[-] The following 6 users Like arshiakh's post:6 users Like arshiakh's post
  • Jackass, jcbv, malc, blaze, Dell_Brett, kowheng
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
03-23-2013, 12:01 PM
Get it here;
[-] The following 5 users Like ssobhan's post:5 users Like ssobhan's post
  • blaze, Dell_Brett, kowheng, procvlu, malc
  Journal: Steel Construction, Design and Research struceng 6 11,935 08-30-2015, 09:39 PM
Last Post: hodzicemir
  AISC RESEARCH ON STRUCTURAL STEEL TO RESIST BLAST AND PROGRESSIVE COLLAPSE TAFATNEB 0 3,612 10-22-2013, 06:40 PM
  Journal of Engineering Mechanics - Papers lisine 3 7,601 06-28-2013, 09:24 AM
  Journal of Materials in Civil Engineering - Papers lisine 3 8,291 06-28-2013, 09:24 AM
  Journal of Structural Engineering - Papers lisine 10 18,863 06-07-2013, 06:41 AM
  Journal Engineering Structures - Papers lisine 6 12,009 04-10-2013, 07:01 AM
  International Journal of Geomechanics - Requested papers lisine 3 7,642 02-26-2013, 08:47 AM
