Civil Engineering Association eBooks Journals, Papers and Presentations Journal of Materials in Civil Engineering - Papers
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,708 in 1,305 posts
Given Likes: 4621
06-18-2012, 11:54 AM (This post was last modified: 06-18-2012, 11:55 AM by lisine.)
Structural Capacity of Rammed Earth in Compression
Author: Maniatidis Vasilios, Walker Peter | Size: 0.97 MB | Format: PDF | Quality: Original preprint | Publisher: Journal of Materials in Civil Engineering, Vol. 20, Issue 3 | Year: Mar2008, | pages: p230-238, 9p | ISSN: 0899-1561
Rammed earth walls are formed by compacting subsoil in thin layers inside temporary supporting formwork. An ancient form of construction, rammed earth has in recent years, together with other earth building methods, been increasingly used structurally in a range of contemporary buildings in many countries around the world. Though current structural design procedures for earth walls, including rammed earth, in general use provisions based on structural masonry standards, this approach has never been satisfactorily validated. This paper presents experimental results from material and large-scale testing and develops a simple theoretical model, applied to rammed earth columns subject to concentric and eccentric axial compression loading. An analytical model, using a basic strut theory, shows favorable correlation with the experimental results for all load eccentricities.
Soil Property Criteria for Rammed Earth Stabilization
Author: Burroughs Steve | Size: 0.39 MB | Format: PDF | Quality: Original preprint | Publisher: Journal of Materials in Civil Engineering, Vol. 20, Issue 3 | Year: Mar2008, | pages: p264-273, 10p | ISBN: 0899-1561
This study relates value ranges of natural soil properties (plasticity, texture, and shrinkage) to the degree of predisposition of soils to stabilization for rammed earth wall construction. A total of 219 strength determinations were made on 104 soils compacted and stabilized with cement and/or lime and/or asphalt. Using a 2 MPa compressive strength criterion as the measure of stabilization success, soil property value ranges were related to the proportion of samples exceeding the criterion. Linear shrinkage (LS) and plasticity index (PI) are found to be the best discriminators of soil predisposition, with textural variables being useful secondary discriminators. “Favorable” soils, with stabilization success rates of ≥80%, include those with: (1) LS<6.0% and PI<15%; and (2) LS 6.0–11.0%, PI 15–30%, and sand content <64%. These soils were stabilized with treatments averaging 4.2% cement and 1.8% lime, with individual treatments ranging from 4–8% total cement and/or lime. “Unfavorable” soils, with stabilization success rates of <60%, include those with LS 6.0–11.0, PI 15–30, and sand content ≥64%, or with LS>11.0, PI>30. These findings should assist rammed earth engineers to more easily select a suitable soil and to minimize resources spent on preconstruction stabilization trials.
Both papers inside 1.16Mb Rar file / no pass.
[-] The following 8 users Like lisine's post:8 users Like lisine's post
  • blaze, zrilek, oanm2000, sodapas, malc, kowheng, Dell_Brett, Mohammad6299
 lisine
Vanuatu
User ID: 17927
Threads: 272
Given Likes: 4621
07-30-2012, 01:03 PM
Correlation of Rheological Properties to Durability and Strength of Hardened Concrete
Author: S. E. Chidiac; O. Maadani; A. G. Razaqpur; N. P. Mailvaganam | Size: 0.13 MB | Format: PDF | Quality: Original preprint | Publisher: Journal of Materials in Civil Engineering; Vol. 15 Issue 4 | Year: Aug2003, | pages: p391-399, 9p | ISSN: 08991561
Premature deterioration of concrete structures has created awareness and concern about the durability of concrete. Concrete mixtures used in the construction of residential basement walls and foundations have a high water to cement (w/c) ratio (w/c>0.6) and low cement content (<280 kg/m[sup 3]). The result is friable concrete with a highly porous surface layer and high potential for cracking. The defects have a direct impact on the durability of concrete. This experimental study examines the effects of three parameters—mix design, formwork, and consolidation—on the quality of the surface of high w/c concrete. The fresh concrete is characterized using its rheological properties—in particular, its yield stress and plastic viscosity. Pulse velocity, pull-off strength, and compressive strength were measured to evaluate the quality and the mechanical properties of the hardened concrete. The durability of the hardened concrete was evaluated by measuring its surface transport properties—namely, its air permeability and sorptivity. The results show that it is possible to correlate the rheological properties of fresh concrete to the mechanical and permeation properties of the hardened concrete.
[-] The following 11 users Like lisine's post:11 users Like lisine's post
  • gulilero, zrilek, malc, Jackass, kowheng, Dell_Brett, techno, cace-01, louislouis, Mohammad6299, sodapas
 lisine
Vanuatu
User ID: 17927
Threads: 272
Given Likes: 4621
10-15-2012, 12:28 PM
General Viscoelastic Solutions for Multilayered Systems Subjected to Static and Moving Loads
Author: Kim, Jaeseung | Size: 0.88 MB | Format: PDF | Quality: Original preprint | Publisher: Journal of Materials in Civil Engineering; Vol. 23 Issue 7 | Year: Jul2011 | pages: p1007-1016, 10p
[Image: 53841702158781858530.jpg]
  • cace-01, zrilek, Mohammad6299, malc, kowheng, Dell_Brett, mary, sodapas
 lisine
Vanuatu
User ID: 17927
Threads: 272
Given Likes: 4621
06-28-2013, 09:24 AM
Determination of Viscoelastic Poisson's Ratio and Creep Compliance from the Indirect Tension Test
Author: Hyung Suk Lee; Jaeseung Kim. | Size: 0.28 MB | Format: PDF | Quality: Original preprint | Publisher: Journal of Materials in Civil Engineering. Aug2009, Vol. 21 Issue 8, | pages: 416-425.
[Image: 43595976648095673210.jpg]
[-] The following 6 users Like lisine's post:6 users Like lisine's post
  • Dell_Brett, Mohammad6299, kowheng, malc, shadabg, tluc
  CTBUH Collection of Technical Papers - Wind Engineering gulilero 1 7,826 03-14-2021, 06:15 AM
Last Post: civilphongvan
  The AISC Engineering Journal Archive [1964-2001] agelos100 2 7,700 03-02-2020, 01:50 AM
  AISC Engineering Journal Fourth Quarter 2014 Volume 51, No. 4 malc 1 6,530 10-15-2014, 07:26 AM
Last Post: Saze808
  ACI Materials Journal May - June 2014 V. 111 No. 3 RyanRS 0 4,093 07-12-2014, 08:07 PM
Last Post: RyanRS
  Journal of Engineering Mechanics - Papers lisine 3 7,599 06-28-2013, 09:24 AM
  Journal of Structural Engineering - Papers lisine 10 18,863 06-07-2013, 06:41 AM
  Journal Engineering Structures - Papers lisine 6 12,009 04-10-2013, 07:01 AM
