Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 1380:2009 Timber structures — Test methods — Load bearing nails, screws, dowels an
11-24-2010, 06:42 AM
EN 1380:2009 Timber structures — Test methods — Load bearing nails, screws, dowels and bolts
Author: CEN/TC 124 | Size: 1.1 MB | Format: PDF | Publisher: CEN | Year: 2009 | pages: 18 | ISBN: 978 0 580 56920 3
[Image: 83610990345483087304.jpg]
This European Standard specifies test methods for determining the strength and deformation characteristics of
laterally loaded connections with nail, screws, dowels and bolts in load-bearing timber structures.
The methods assess connections with members of timber (solid timber or glued laminated timber) or wood-based
products or metal plates (but not punched metal plate fasteners) in the combination proposed for use in service.
The methods are used to determine load-slip characteristics and maximum load of connections where various
angles between the applied force and the timber grain direction, or the main direction of the wood-based products,
respectively, are possible.
  • kowheng, Dell_Brett, toa011, zrilek, shanta, usman, roaming79, vvvv, gulilero, nowanda
  EN 12350-2:2009 Testing fresh concrete - Part 2: Slump-test ir_71 2 4,658 01-11-2021, 12:19 PM
  EN 13670:2009 Execution of concrete structures ir_71 5 4,905 11-14-2016, 12:15 PM
Last Post: PinkPant
  EN ISO 6892-1:2009 Metalic materials. Part 1:Method of test at room te Method of test ir_71 2 2,788 03-12-2016, 04:51 PM
  EN 1052 Methods of test for masonry ir_71 3 3,283 11-06-2015, 01:59 AM
Last Post: concreteok
  EN 1015 Methods of test for mortar for masonry ir_71 2 2,830 05-02-2014, 07:53 PM
  EN 520:2004 Gypsum plasterboards - Definitions, requirements and test methods ir_71 2 2,913 09-08-2011, 09:02 AM
  EN 1912:2004+A3:2009 Structural timber - Strength classes - Assignment of visual grad ir_71 0 1,907 01-25-2011, 05:21 AM
