Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 520:2004 Gypsum plasterboards - Definitions, requirements and test methods
11-17-2010, 05:44 AM (This post was last modified: 08-28-2011, 08:27 AM by Dell_Brett.)
This document specifies the characteristics and performance of gypsum plasterboards intended to be used in
building construction works including those intended for secondary manufacturing operations. It includes boards
designed to receive either direct surface decoration or gypsum plaster.
This document covers the following product performance characteristics: reaction to fire, water vapour permeability,
flexural strength (breaking load), impact resistance and thermal resistance.
The following performance characteristics are linked to systems assembled with plasterboards: shear strength, fire
resistance, impact resistance direct airborne sound insulation and acoustic absorption to be measured according to
the corresponding European test methods. If required, tests should be done on assembled systems simulating the
end use conditions.
This document covers also additional technical characteristics that are of importance for the use and acceptance of
the product by the Construction Industry and the reference tests for these characteristics.
It provides for the evaluation of conformity of the product to this document.
This document does not cover plasterboards, which have been subject to any secondary manufacturing operations
(e.g. insulating composite panels, plasterboards with thin lamination, etc.).
Dear friends, there is a new annex to this standard - from 2009, if someone of you have it - please share it.
:JC_cheers:
  • Administrator , kowheng, Grunf, Dell_Brett, toa011, peixoto, Jackass, oanm2000, vvvv
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 264
Likes: 19,035 in 2,188 posts
Given Likes: 42470
08-28-2011, 08:37 AM
This is a temporary post: Until we have a new valid link, this Code could be read here:
[-] The following 6 users Like Dell_Brett's post:6 users Like Dell_Brett's post
  • zrilek, blaze, Grunf, jayborre, oanm2000, Jackass
09-08-2011, 09:02 AM
New links for EN 520.
  • Dell_Brett, Grunf, oanm2000, engr1900, Jackass, ting tsai huang, zrilek, sivlad, duazo2009, CAMSECT
  EN 1052 Methods of test for masonry ir_71 3 3,235 11-06-2015, 01:59 AM
Last Post: concreteok
  EN 1015 Methods of test for mortar for masonry ir_71 2 2,775 05-02-2014, 07:53 PM
  EN 12812:2004 Falsework - Performance requirements and general design ir_71 1 2,559 09-07-2012, 07:23 AM
Last Post: mremremre
  EN 14487-1:2005 Sprayed concrete - Part 1: Definitions, specifications and conformity datagap 0 2,016 01-17-2011, 08:39 PM
Last Post: datagap
  EN 13318:2000 Screed material and floor screeds - Definitions datagap 0 1,841 12-30-2010, 10:39 AM
Last Post: datagap
  EN 1380:2009 Timber structures — Test methods — Load bearing nails, screws, dowels an ir_71 0 1,861 11-24-2010, 06:42 AM
  EN 14566:2008 Mechanical fasteners for gypsum plasterboard systems - Definitions, re ir_71 0 1,777 11-17-2010, 05:49 AM
