Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 1015 Methods of test for mortar for masonry
01-22-2011, 07:25 AM (This post was last modified: 01-22-2011, 08:19 AM by ir_71.)
Author: CEN/TC 125 | Size: 0.35 MB | Format: PDF | Publisher: CEN | Year: 1998 | pages: 8
[Image: 03305846704485785151.jpg]
Methods of test for mortar for masonry - Part 1: Determination of particle size distribution (by sieve analysis)
Author: CEN/TC 125 | Size: 0.1 MB | Format: PDF | Publisher: CEN | Year: 1998 | pages: 8
[Image: 49319442900876973999.jpg]
EN 1015-2:1998 Methods of test for mortar for masonry - Part 2: Bulk sampling of mortars and preparation of test mortars
Author: CEN/TC 125 | Size: 0.5 MB | Format: PDF | Publisher: CEN | Year: 1999 | pages: 10
[Image: 46032164720012247546.jpg]
EN 1015-3:1999 Methods of test for mortar for masonry - Part 3: Determination of consistence of fresh mortar (by flow table)
This European Standard specifies a method for determining the consistence of freshly mixed mortars (in the following briefly referred to as fresh mortars) including those containing mineral binders and both normal weight and lightweight aggregates, which is by means of the flow value.
Author: CEN/TC 125 | Size: 0.5 MB | Format: PDF | Publisher: CEN | Year: 1998 | pages: 8
[Image: 15432753634790717861.jpg]
EN 1015-4:1998 Methods of test for mortar for masonry - Part 4: Determination of consistence of fresh mortar (by plunger penetration)
This European Standard specifies a method for determining the consistence of freshly mixed mortars (in the following briefly referred to as fresh mortars) including those containing mineral binders and both dense and lightweight aggregates, which is by means of the plunger penetration value.
Author: CEN/TC 125 | Size: 0.4 MB | Format: PDF | Publisher: CEN | Year: 1998 | pages: 8
[Image: 08018694476176176239.jpg]
EN 1015-6:1998 Methods of test for mortar for masonry - Part 6: Determination of bulk density of fresh mortar
This European Standard specifies a method for the determining the bulk density of fresh mortars including those containing mineral binders and both dense and lightweight aggregates.
Author: CEN/TC 125 | Size: 0.4 MB | Format: PDF | Publisher: CEN | Year: 1998 | pages: 10
[Image: 88083728245591689609.jpg]
EN 1015-9:1999 Methods of test for mortar for masonry - Part 9: Determination of workable life and correction time of fresh mortar
This European Standard specifies methods for determining the workable life and correction time of freshly mixed mortars (in the following referred to as fresh mortars). Method A is a method for the determination of the workable life of general purpose masonry or rendering mortars, including those containing mineral binders and both dense and lightweight aggregates. Methods B and C are methods for the determination of the workable life and correction time for thin layer mortars.
Author: CEN/TC 125 | Size: 0.3 MB | Format: PDF | Publisher: CEN | Year: 1999 | pages: 8
[Image: 14181554797619271434.jpg]
EN 1015-10:1999/A1:2006 Methods of test for mortar for masonry - Part 10: Determination of dry bulk density of hardened mortar
[Image: 97775465694869246819.jpg]
EN 1015-11:1999/A1:2006 Methods of test for mortar for masonry - Part 11: Determination of flexural and compressive strength of hardened mortar
Author: CEN/TC 125 | Size: 0.15 MB | Format: PDF | Publisher: CEN | Year: 2002 | pages: 12
[Image: 11682562977282592610.jpg]
EN 1015-21:2002 Methods of test for mortar for masonry - Part 21: Determination of the compatibility of one-coat rendering mortars with substrates
This European Standard specifies a test method for the evaluation of the compatibility with given backgrounds of One-Coat (OC) rendering mortars. The evaluation is based on the determination of the adhesion strength and water permeability of the hardened render applied on tested substrates, after exposure to weathering cycles.
Dear friends,
I decided to combine EN 1015 standard series and I hope with your help to collect all the standards of this series.
IR
  • kowheng, datagap, Dell_Brett, toa011, Grunf, Adam Smith, st77bel, usman, oanm2000, zrilek, roaming79, spy1551
 cod-X
Semi Senior Member
User ID: 45
Threads: 47
Likes: 504 in 63 posts
Given Likes: 269
05-02-2014, 10:38 AM
can someone renew all links please?
>> First learn from cracked software than be licensed1 <<
05-02-2014, 07:53 PM
  • Mohammad6299, malc, Dell_Brett, PinkPant, zrilek, concreteok
  EN 1052 Methods of test for masonry ir_71 3 3,285 11-06-2015, 01:59 AM
Last Post: concreteok
  EN 520:2004 Gypsum plasterboards - Definitions, requirements and test methods ir_71 2 2,914 09-08-2011, 09:02 AM
  EN 1745 Masonry. Methods for determining design thermal values datagap 0 1,762 12-17-2010, 11:03 PM
Last Post: datagap
  EN 1380:2009 Timber structures — Test methods — Load bearing nails, screws, dowels an ir_71 0 1,898 11-24-2010, 06:42 AM
