Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 12350-2:2009 Testing fresh concrete - Part 2: Slump-test
10-30-2010, 04:09 AM (This post was last modified: 06-04-2011, 08:11 AM by Dell_Brett.)
[Image: 25940747570015717445.jpg]
This European standard specifies a method for determining the consistence of fresh concrete by the slump
test.
The slump test is sensitive to changes in the consistence of concrete, which correspond to slumps between
10 mm and 200 mm. Beyond these extremes the measurement of slump can be unsuitable and other
methods of determining the consistency should be considered.
If the slump continues to change over a period of 1 min after de-moulding, the slump test is not suitable as a
measure of consistence.
The test is not suitable when the maximum size of aggregate in the concrete is greater than 40 mm.
Is there anyone who does not know this method?:JC_shhh:
  • Dell_Brett, kowheng, ziggywas1, avscorreia, Grunf, roaming79, toa011, StaadEng, salahcivil, peixoto, axee1980, mappoggio, sivlad
07-02-2014, 05:15 PM
  • zrilek, Mohammad6299, Dell_Brett, malc, PinkPant, ssobhan, bridgeengineer
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,709 in 1,305 posts
Given Likes: 4621
01-11-2021, 12:19 PM
[-] The following 6 users Like lisine's post:6 users Like lisine's post
  • babakfeyzi, zrilek, CAMSECT, nhim4mat2006, Dell_Brett, oanm2000
  EN 14488 Testing sprayed concrete datagap 5 6,462 11-06-2024, 08:31 AM
  BS EN ISO 22476-10: Geotechnical investigation and testing - Field testing - Part 10: poolmand 0 2,717 09-20-2023, 11:31 AM
  EN 196-1: 2005 Methods of testing cement - Part 1: Determination of strength ir_71 2 4,555 02-12-2022, 07:32 AM
  EN 1011-1:2009 Welding — Recommendations for welding of metallic materials Part 1: Ge ir_71 2 3,405 04-09-2017, 04:00 AM
  EN ISO 6892-1:2009 Metalic materials. Part 1:Method of test at room te Method of test ir_71 2 2,789 03-12-2016, 04:51 PM
  EN 206-9:2010 Concrete Part 9: Additional Rules for Selfcompacting Concrete (SCC) ir_71 2 3,574 09-19-2012, 02:21 PM
Last Post: miquan
  EN 14487-1:2005 Sprayed concrete - Part 1: Definitions, specifications and conformity datagap 0 2,055 01-17-2011, 08:39 PM
Last Post: datagap
