Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 14488 Testing sprayed concrete
 datagap
User ID: 24267
Threads: 48
Likes: 695 in 68 posts
Given Likes: 176
01-17-2011, 09:08 PM (This post was last modified: 01-21-2011, 01:27 AM by datagap.)
EN 14488-2:2006 Testing sprayed concrete - Part 2: Compressive strength of young sprayed concrete
Author: CEN/TC 104 “Concrete and related products” | Size: 0.19 MB | Format: PDF | Publisher: CEN | Year: 2006 | pages: 10
[Image: 83382420544576452710.png]
This series EN 14488 ‘Testing sprayed concrete’ includes the following parts:
- Part 1: Sampling fresh and hardened concrete
- Part 3: Flexural strengths (first peak, ultimate and residual) of fibre reinforced beam specimens
- Part 4: Bond strength of cores by direct tension
- Part 5: Determination of energy absorption capacity of fibre reinforced slab specimens
- Part 6: Thickness of concrete on a substrate
- Part 7: Fibre content of fibre reinforced concrete
Part 2 specifies two methods from which an estimate of the in situ compressive strength of young hardened sprayed concrete can be made.
EN 14488-3:2006 Testing sprayed concrete - Part 3: Flexural strengths (first peak, ultimate and residual) of fibre reinforced beam specimens
Author: CEN/TC 104 “Concrete and related products”, | Size: 0.18 MB | Format: PDF | Publisher: CEN | Year: 2006 | pages: 12
[Image: 74365004296127953371.png]
This part of European Standard specifies a method for the determination of the flexural (first peak, ultimate and residual) strength of beam specimens of hardened sprayed concrete.
EN 14488-5:2006 Testing sprayed concrete - Part 5: Determination of energy absorption capacity of fibre reinforced slab specimens
Author: EN/TC 104 “Concrete and related products”, | Size: 0.13 MB | Format: PDF | Publisher: CEN | Year: 2006 | pages: 8
[Image: 88848407869590028437.png]
This part of European Standard specifies a method for the determination of the load/deflection response of aslab specimen in order to calculate the energy absorption capacity up to a specified deflection.
EN 14488-6:2006 Testing sprayed concrete - Part 6: Thickness of concrete on a substrate
Author: CEN/TC 104 “Concrete and related products” | Size: 0.1 MB | Format: PDF | Publisher: CEN | Year: 2006 | pages: 7
[Image: 75110815242540098448.png]
This standard describes methods for the determination of the thickness of sprayed concrete on a substrate after spraying. The results can also give an indication of the parallelism of the concrete to the substrate. The substrate may be rock, soil, concrete or other surface.
EN 14488-7:2006 Testing sprayed concrete - Part 7: Fibre content of fibre reinforced concrete
Author: CEN/TC 104 “Concrete and related products” | Size: 0.12 MB | Format: PDF | Publisher: CEN | Year: 2006 | pages: 6
[Image: 96969064254582822420.png]
This part of European Standard specifies a method for the determination of the fibre content of sprayed concrete from either a fresh or hardened (i.e. before or after set) concrete sample. Only the method using a fresh sample is appropriate with polymer fibres, while both types are applicable with steel fibres.
[-] The following 12 users Like datagap's post:12 users Like datagap's post
  • usman, toa011, oanm2000, kowheng, ir_71, zrilek, super_engineer, Dell_Brett, roaming79, Clouseau, ykhackhack, nhim4mat2006
01-18-2011, 06:04 AM
EN 14488-1:2005 Testing sprayed concrete - Sampling fresh and hardened concrete
Author: CEN/TC 104 | Size: 0.2 MB | Format: PDF | Publisher: CEN | Year: 2005 | pages: 8
[Image: 00503652408226269613.jpg]
This European Standard specifies a method for obtaining samples of fresh or hardened (i.e. before or after
set) sprayed concrete, depending on the property to be measured and its associated test method.
  • kowheng, blaze, datagap, zrilek, super_engineer, usman, Dell_Brett, roaming79, Clouseau, ykhackhack, nhim4mat2006
01-18-2011, 07:18 AM
EN 14488-4:2005 Part 4: Bond strength of cores by direct tension
Author: CEN/TC 104 | Size: 0.9 MB | Format: PDF | Publisher: CEN | Year: 2005 | pages: 8
[Image: 88678998384903660110.jpg]
This European Standard describes a means of determining the tensile bond between sprayed concrete and
substrate of concrete or rock tested in a laboratory as a direct tension test. Bond strength is defined as the
capacity to transfer tension between two layers. Bond strength is calculated as the ultimate tensile force
divided by the stressed cross-sectional area of a core, drilled out of a sprayed concrete layer together with a
portion of the substrate concrete or rock.
  • kowheng, datagap, zrilek, super_engineer, usman, Dell_Brett, roaming79, Clouseau, ykhackhack, nhim4mat2006
04-09-2013, 07:02 PM
EN 14488 all parts:
  • Jackass, superberti, andersen3, SR71, st77bel, nhim4mat2006, Dell_Brett
11-12-2016, 10:27 AM
New links for EN 14488 all parts
  • PinkPant, Jackass, Dell_Brett, zrilek, K.Lee
11-06-2024, 08:31 AM (This post was last modified: 11-12-2024, 08:25 AM by lisine.)
EN 14488 all parts
BS_EN_14488_1_2005
BS_EN_14488_2_2006
BS_EN_14488_3_2023
BS_EN_14488_4_2008
BS_EN_14488_5_2006
BS_EN_14488_6_2006
BS_EN_14488_7_2006
  • babakfeyzi, Dell_Brett, lisine
  EN 14487-1:2005 Sprayed concrete - Part 1: Definitions, specifications and conformity datagap 0 2,046 01-17-2011, 08:39 PM
Last Post: datagap
