Civil Engineering Association eBooks Journals, Papers and Presentations Seismic Reliability Analysis of Cable Stayed Bridges Against First Passage Failure
05-03-2014, 09:46 AM
Author: Rehan Ahmad Khan Aligarh Muslim University India | Size: 810 KB | Format: PDF | Quality: Unspecified | pages: 29
[Image: 01034409417053932059.jpg]
In many structural applications, the ultimate purpose of using stochastic analysis is to determine the reliability of a structure, which has been designed to withstand the random
excitations. The present study is concerned with one of the failures, which are the results of the dynamic response of the stable cable stayed bridges. If Y(t) is the dynamic response (either deflection, strain or stress) of the bridge at a critical point, the bridge may fail upon the occurrence of one of the following cases (Y.K. Lin, 1967):
  • vardan, malc, blaze, zrilek, slowet
  Performance-based seismic assessment of skewed bridges bridgeengineer 0 5,105 04-22-2016, 06:31 AM
Last Post: bridgeengineer
  Seismic behavior of box girder cable-stayed bridges considering large deformations arshiakh 1 6,035 03-01-2015, 08:09 PM
  Reliability Analysis of Steel Building Frame Under Earthquake Forces TAFATNEB 0 3,964 05-09-2014, 10:56 AM
  Investigation of the behavior of the cable-stayed bridge under test load TAFATNEB 0 3,966 05-02-2014, 09:19 AM
  Finite Elements Analysis Techniques of Ve ssel Collision with Cable-Stayed Bridge TAFATNEB 0 3,601 05-02-2014, 09:12 AM
  Seismic Retrofit of a Cable-S tayed Bridge with Passive Control Techniques: A Comp ar TAFATNEB 0 4,147 05-02-2014, 09:08 AM
  SEISMIC RETROFIT STUDY OF CABLE-STAYED BRIDGE ON TOKYO-GAIKAN EXPRESSWAY TAFATNEB 0 3,986 05-02-2014, 08:58 AM
