Civil Engineering Association eBooks Journals, Papers and Presentations Seismic Retrofit of a Cable-S tayed Bridge with Passive Control Techniques: A Comp ar
05-02-2014, 09:08 AM
Seismic Retrofit of a Cable-S tayed Bridge with Passive Control Techniques: A Comp arative Investigation through Non-Linear Dynamic Analyses
Author: M.D. Martínez-Rodrigo ; A. Filiatrault | Size: 536 KB | Format: PDF | Quality: Unspecified | Publisher: Department. of Civil, Structural and Environmental Engineering, State University of New York at Buffalo, USA | Year: 2012 | pages: 10
The present contribution deals with the seismic performance of an existing cable-stayed steel bridge. The structure experienced damage during the Saguenay earthquake in 1988 needing structural rehabilitation. As an alternative, in this study the retrofit of the structure with different passive supplemental damping and seismic isolation systems is proposed and evaluated in order to achieve an admissible performance of the bridge under a set of seismic events of different magnitudes including near field records. To this end a Finite Element numerical planar model is implemented and the bridge response is obtained trough non-linear dynamic analyses. Strength degradation capabilities are included in the model allowing the occurrence of brittle failure when certain levels of ductility are exceeded in the members. The major improvement in the overall response of the bridge is shown
and conclusions regarding the most appropriate retrofit alternative for the particular case are derived.
  • vardan, warlord1, blaze, subin91, zrilek, malc, bridgeengineer, slowet
  Seismic behavior of box girder cable-stayed bridges considering large deformations arshiakh 1 6,037 03-01-2015, 08:09 PM
Last Post: bridgeengineer
  seismic retrofit of existing buildings : innovative alternatives TAFATNEB 0 4,026 05-09-2014, 11:08 AM
  Seismic Reliability Analysis of Cable Stayed Bridges Against First Passage Failure TAFATNEB 0 4,119 05-03-2014, 09:46 AM
  SIMULATION TECHNIQUES FOR COLLAPSE ANALYSIS OF RC BRIDGE UNDER STRONG EARTHQUAKE TAFATNEB 0 4,278 05-03-2014, 09:39 AM
  Investigation of the behavior of the cable-stayed bridge under test load TAFATNEB 0 3,968 05-02-2014, 09:19 AM
  Finite Elements Analysis Techniques of Ve ssel Collision with Cable-Stayed Bridge TAFATNEB 0 3,601 05-02-2014, 09:12 AM
  SEISMIC RETROFIT STUDY OF CABLE-STAYED BRIDGE ON TOKYO-GAIKAN EXPRESSWAY TAFATNEB 0 3,988 05-02-2014, 08:58 AM
