Civil Engineering Association eBooks Journals, Papers and Presentations Investigation of the behavior of the cable-stayed bridge under test load
Likes: 9,406 in 1,160 posts
05-02-2014, 09:19 AM
Author: Rastislav Mandi} , Gordana Had`i-Nikovi} and Stanko ]ori} | Size: 784 KB | Format: PDF | Quality: Unspecified | Publisher: GEOFIZIKA VOL. 28 2011 | Year: 2011 | pages: 16
A field load testing is an effective method for understanding the behavior
and fundamental characteristics of cable-stayed bridges. This paper presents results of the behavior of the reconstructed cable-stayed bridge over river Danube in Novi Sad under test load. The bridge was built between 1976 and 1981 and in 1999 was heavily damaged by two Tomahawk missiles. In 2003 process of the reconstruction began and at the end of 2005 Faculty of Civil Engineering, University of Belgrade was invited to test reconstructed bridge structure.
The results of static load testing presented herein include displacements,
rotations and strains of the 351 m long main span. Vibrations of the bridge
were obtained by impact load produced by heavy truck passing the bridge and the time history response of vertical accelerations was recorded. The frequency content of the signals was determined using Fourier transformation and five flexural natural periods were extracted. The geological structure and engineering properties of the soil are also given. A finite element model of the bridge was made and a good agreement is achieved between the experimental and analytical results. These results have shown that the bridge is in the elastic state under the code-specified serviceability load, which indicates that the bridge has adequate load-carrying capacity and can be put safely into service.
  • vardan, blaze, zrilek, malc, slowet, civilphongvan
  Seismic behavior of box girder cable-stayed bridges considering large deformations arshiakh 1 5,845 03-01-2015, 08:09 PM
Last Post: bridgeengineer
  Seismic Reliability Analysis of Cable Stayed Bridges Against First Passage Failure TAFATNEB 0 3,937 05-03-2014, 09:46 AM
  Finite Elements Analysis Techniques of Ve ssel Collision with Cable-Stayed Bridge TAFATNEB 0 3,451 05-02-2014, 09:12 AM
  Seismic Retrofit of a Cable-S tayed Bridge with Passive Control Techniques: A Comp ar TAFATNEB 0 3,985 05-02-2014, 09:08 AM
  SEISMIC RETROFIT STUDY OF CABLE-STAYED BRIDGE ON TOKYO-GAIKAN EXPRESSWAY TAFATNEB 0 3,800 05-02-2014, 08:58 AM
  Pushover analysis for the seismic response prediction of cable-stayed bridge TAFATNEB 0 3,761 11-20-2013, 10:33 PM
  CABLE STAYED BRIDGE WITH SAP 2000 mowafi3m 2 5,635 04-19-2013, 11:35 AM
Last Post: rezart
