Civil Engineering Association eBooks Journals, Papers and Presentations Seismic behavior of box girder cable-stayed bridges considering large deformations
 arshiakh
User ID: 37777
Threads: 100
Likes: 3,224 in 617 posts
Given Likes: 214
08-03-2014, 12:09 PM
Author: Halabian, Amir M.; Keshtegar, Behrouz; Hashemolhosseini, S. Hamid | Size: 440 KB | Format: PDF | Quality: Unspecified | Publisher: NISEE e-Library | Year: 2007 | pages: 9
The main purpose of this study is to consider large deformations of the deck in response of long-span cable-stayed bridges during seismic excitations taking into account both kinds of geometric and material non-linearities. A 3D finite element model was developed. Large deformation beam elements with very low bending stiffness were used to model main supporting cables. The orthotropic deck was represented in the model with large deformation shell elements. Non-linear time history analyses using explicit approach were performed for a practical cable-stayed bridge subjected to different ground excitations considering ground motion spatial variation. In a parametric study the effects of the spatial variation in ground motions and cables’ post-tensioned forces on seismic response of the structure were examined. Results of time history analyses indicated that neglecting large deformations could lead one to overestimate the stiffness of the deck in some areas.
[-] The following 11 users Like arshiakh's post:11 users Like arshiakh's post
  • ssobhan, warlord1, blaze, oanm2000, Dell_Brett, zrilek, malc, subin91, slowet, Mohammad6299, sia1
Away  bridgeengineer
Semi Senior Member
Banned
Poland
User ID: 93214
Threads: 49
Likes: 1,023 in 110 posts
Given Likes: 4769
03-01-2015, 08:09 PM
here you go
[-] The following 7 users Like bridgeengineer's post:7 users Like bridgeengineer's post
  • jfjdm, Dell_Brett, ashcivilea, amindoxiti, stigtg, PinkPant, melekeen
  Cause of Cracking in Post-Tensioned Concrete Box Girder Bridges and Retrofit Proced. Aviator 2 7,806 11-18-2020, 04:13 AM
Last Post: tomtumx
  Performance-based seismic assessment of skewed bridges bridgeengineer 0 5,115 04-22-2016, 06:31 AM
Last Post: bridgeengineer
  SEISMIC BEHAVIOR OF DAMAGED BUILDINGS: A COMPARISON OF STATIC AND DYNAMIC NONLINEAR A TAFATNEB 0 4,091 08-10-2014, 02:06 PM
  Seismic Behavior of RC Elevated Water Tankunder Different Types of Staging Pattern TAFATNEB 0 4,230 05-10-2014, 08:16 AM
  Seismic Reliability Analysis of Cable Stayed Bridges Against First Passage Failure TAFATNEB 0 4,128 05-03-2014, 09:46 AM
  Seismic analysis of a three- span deck girder bridge TAFATNEB 0 3,933 05-03-2014, 09:01 AM
  Investigation of the behavior of the cable-stayed bridge under test load TAFATNEB 0 3,973 05-02-2014, 09:19 AM
