Civil Engineering Association eBooks Journals, Papers and Presentations Seismic analysis of a three- span deck girder bridge
05-03-2014, 09:01 AM
Author: Zasiah Tafheem & Nazmus Sakib | Size: 625 KB | Format: PDF | Quality: Unspecified | Publisher: IABSE-JSCE Joint Conference on Advances in Bridge Engineering-II, August 8-10, 2010, Dhaka, Bangladesh. Amin, Okui, Bhuiyan (eds.) | Year: 2010 | pages: 08
[Image: 69412064012668751683.jpg]
This paper presents seismic analysis of a three-span deck girder bridge. A finite element model to analyze the deck girder bridge has been developed by using finite element software called ANSYS. The entire work has been carried out in two steps. In the first step, a three dimensional model of the bridge has been subjected to equivalent static earthquake loading by following AASHTO guideline. In the second step, Response
Spectrum analysis has been performed. Then the design forces and moments at the column bases of the bridge are obtained by using the above two methods. Finally a comparative study of the design values has been performed between those two methods mentioned above. From the entire study it has been found that the magnitude of the axial forces are almost same in those two methods but the design moments and shear forces
vary significantly. In case of design moment, the result found from response spectrum method (RSM) is about
1.74 times of the design value obtained by equivalent static force method (ESFM). Therefore it can be said that there is a possibility of achieving under design of the bridge if follows the ESFM. Based on overall findings, it can be suggested that the response spectrum method should be performed for seismic load analysis of the bridge to achieve a safer design.
  • PinkPant, vardan, malc, blaze, rezart, zrilek, bridgeengineer, ashcivilea, subin91, slowet
  Seismic behavior of box girder cable-stayed bridges considering large deformations arshiakh 1 6,045 03-01-2015, 08:09 PM
Last Post: bridgeengineer
  [ASCE] Buckling Analysis of a Long‐Span Roof Structure Collapsed during Construction mybest 1 5,920 04-08-2014, 11:35 AM
Last Post: Mohammad6299
  Pushover Analysis of Long Span Bridge Bents TAFATNEB 0 4,244 12-12-2013, 08:35 PM
  Pushover analysis for the seismic response prediction of cable-stayed bridge TAFATNEB 0 3,939 11-20-2013, 10:33 PM
  Fatigue life estimation of steel girder of Yangpu cable-stayed Bridge due to buffetin asim99 0 3,886 03-31-2013, 04:33 PM
Last Post: asim99
  Optimized Sections for High-Strength Concrete Bridge Girders—Effect of Deck Concrete ir_71 1 6,073 03-02-2013, 05:08 AM
Last Post: arshiakh
  FINITE ELEMENT ANALYSIS OF SKEW-CURVED RC BOX GIRDER BRIDGES asim99 0 3,878 11-26-2012, 02:24 PM
Last Post: asim99
