[ASCE] Buckling Analysis of a Long‐Span Roof Structure Collapsed during Construction
Current time: 09-19-2018, 10:11 AM
Author: mybest
Last Post: Mohammad6299
Replies 1
Views 2119
Author: N. Augenti1 and F. Parisi2 | Size: 3.41 MB | Format: PDF | Publisher: ASCE | Year: 2011 | pages: 46
Numerical simulation of damage and collapse mechanisms suffered by engineering structures can be an effective tool for a quantitative assessment of their causes. Large displacement inelastic analysis may be required in the case of highly flexible structures such as steel roofs which frequently experience large failures or even collapse owing to buckling. This paper deals with the collapse of a long‐span steel roof structure which fell down suddenly during construction as a result of an out‐of‐plane buckling phenomenon induced by a gust of wind. Forensic investigations were carried out on behalf of the judicial authority in order to identify the causes of the accident. Based on detailed information gathered from site surveys and project documents, a three‐dimensional numerical model of the as‐built structure was created and buckling analyses were performed to assess the safety level at the moment of the collapse. The as‐built structure was braced through some purlins and steel cables fixed at the ground level. Structural stability was also investigated under further modeling assumptions to compare the effectiveness of several bracing systems in preventing the collapse. Analysis results showed that the as‐built structure was in an unstable equilibrium condition when the wind breeze occurred. Temporary bracing elements installed on the structure instead of concentric roof braces were not sufficient to ensure the overall stability.
[-] The following 17 users say Thank You to mybest for this post:
  • Dell_Brett, kowheng, Jackass, jcbv, cordoba123, batata666, malc, zrilek, slowet, seriousboy, tluc, yanburak, subin91, parhyang, carolinandra, faros3000, ykhackhack
[-] The following 10 users say Thank You to Mohammad6299 for this post:
  • ting tsai huang, blaze, viet2010, milova, subin91, zrilek, cace-01, Dell_Brett, ykhackhack, lisine
Long-term fatigue analysis of multi-planar tubular joints for jacket-type offshore wi TAFATNEB 1 1,753 06-19-2016, 01:48 AM
Last Post: englandboy
Nonlinear Analysis of a Collapsed Reinforced Concrete Chimney TAFATNEB 0 981 08-10-2014, 03:59 PM
Seismic analysis of a three- span deck girder bridge TAFATNEB 0 1,092 05-03-2014, 10:01 AM
Pushover Analysis of Long Span Bridge Bents TAFATNEB 0 1,169 12-12-2013, 09:35 PM
The effects of long term uniform corrosion on the buckling of ground based steel tank arshiakh 0 1,961 04-24-2013, 08:38 PM
Last Post: arshiakh
