Civil Engineering Association eBooks Journals, Papers and Presentations Dynamic stability of cracked columns; the stiffness reduction method
 asim99
User ID: 9774
Threads: 476
Likes: 6,383 in 594 posts
Given Likes: 377
05-11-2013, 06:06 PM
Author: A. Ranjbarana, H. Rousta, M. Ranjbaran, M. Ranjbaran | Size: 890 KB | Format: PDF | Quality: Unspecified | Publisher: Sciencedirect/Elsevier | Year: 2013 | pages: 8
A new formulation for the dynamic stability of cracked columns is proposed. In this formulation,
a differential equation governing the free vibration of a cracked column subjected to compressive axial
force is derived. The solution of the proposed equation needs only the end conditions for its solution
(similar to that of intact beam columns). The equation is solved using the Laplace Transform. Both
conservative and non-conservative forces are considered. The closed form solution is then used in the
dynamic stability investigation of the cracked column with different boundary conditions. The accuracy,
efficiency and robustness of the work are verified through numerical examples.
[-] The following 3 users Like asim99's post:3 users Like asim99's post
  • devilmaycry, malc, kowheng
  Strength reduction FEM in stability analysis of soil slopes subjected to transient un PinkPant 0 5,089 06-03-2015, 07:40 AM
Last Post: PinkPant
  Dynamic Stiffness and Damping of a Shallow Foundation from Forced Vibration of a Fiel TAFATNEB 0 3,479 08-11-2014, 10:20 AM
  A Pseudo-Dynamic Method to Analyze Retaining Wall with Reinforced and Unreinforced Ba TAFATNEB 0 3,390 04-27-2014, 08:29 AM
  Dynamic stability analysis of functionally graded cylindrical shells under periodic a asim99 0 3,357 04-19-2013, 05:27 PM
Last Post: asim99
  Background and Illustrative Eaxample on Proposed Direct Analysis Method for Stability subin91 0 3,546 11-10-2012, 04:59 AM
Last Post: subin91
  Dynamic stiffness of foundation on layered soil half-space using cone frustums mybest 0 4,507 09-19-2012, 02:51 PM
Last Post: mybest
  Dynamic stability of non-linear shells of revolution under consideration of the fluid mybest 0 3,555 06-12-2012, 02:50 PM
Last Post: mybest
