Civil Engineering Association eBooks Journals, Papers and Presentations Dynamic stability of non-linear shells of revolution under consideration of the fluid
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
06-12-2012, 02:50 PM
Dynamic stability of non-linear shells of revolution under consideration of the fluid–soil–structure interaction
Author: W. Wunderlich, B. Schäpertöns, C. Temme | Size: 1 MB | Format: PDF | Quality: Original preprint | Publisher: Wiley, Journal International Journalfor Numerical Methods in Engineering | Year: 15 August 1994 | pages: 2679–2697
The dynamic behaviour of liquid-filled shells of revolution is investigated considering the soil–structure interaction and the fluid–structure interaction, respectively. In the circumferential direction the loads and variables are approximated by Fourier series. The shell is modelled through shell ring elements including non-linear behaviour, coupled with isoparametric continuum ring elements and special infinite elements for the soil and isoparametric pressure ring elements for the fluid. Transient loadings like earthquake excitation and the non-linearities of the shell and the soil require an analysis in the time domain. To reduce the size of the problem, linear parts of the system are condensed by the substructure technique. The soil region is divided into two parts, a near field permitting non-linearities like plastification or uplifting of the shell, and a far field for the treatment of radiation of energy.
The boundary conditions for the shell footing have a strong influence on the distribution of the axial membrane forces and, hence, on the stability limit, which is mostly governed by plastic collapse and caused by the dynamically activated pressure acting on the tank wall. It is shown how the soil properties influence the dynamic stability of the shell under harmonic excitation and under realistic earthquake motion.
[-] The following 9 users Like mybest's post:9 users Like mybest's post
  • lisine, ssobhan, warbeast, zrilek, malc, jcbv, kowheng, Dell_Brett, shadabg
  A parametric study of linear and non-linear passively damped seismic isolation system TAFATNEB 0 3,721 08-28-2013, 10:45 AM
  Dynamic stability of cracked columns; the stiffness reduction method asim99 0 4,023 05-11-2013, 06:06 PM
Last Post: asim99
  Recent research advances on the dynamic analysis of composite shells: 2000–2009 asim99 0 3,488 04-19-2013, 06:13 PM
Last Post: asim99
  Dynamic elastic-plastic buckling of circular cylindrical shells under axial impact asim99 0 3,866 04-19-2013, 06:11 PM
Last Post: asim99
  A new energy and momentum conserving algorithm for the non-linear dynamics of shells asim99 0 3,490 04-19-2013, 05:33 PM
Last Post: asim99
  Dynamic stability analysis of functionally graded cylindrical shells under periodic a asim99 0 3,370 04-19-2013, 05:27 PM
Last Post: asim99
  Spatial rainfall estimation by linear and non-linear co-kriging of radar-rainfall and arshiakh 0 3,618 04-08-2013, 06:06 PM
Last Post: arshiakh
