Civil Engineering Association eBooks Journals, Papers and Presentations A parametric study of linear and non-linear passively damped seismic isolation system
Likes: 9,403 in 1,160 posts
Given Likes: 2855
Points:118,565 EP
08-28-2013, 10:45 AM (This post was last modified: 08-28-2013, 01:05 PM by oanm2000.)
A parametric study of linear and non-linear passively damped seismic isolation systems for buildings
Author: Cenk Alhan, Henri Gavin | Size: 0.5 MB | Format: PDF | Quality: Unspecified | Publisher: Department of Civil and Environmental Engineering, Duke University, Durham, NC 27708-0287, USA | Year: 2004 | pages: 13
The effects of near-field ground motions with large velocity pulses have motivated passive damping requirements for the protection of seismically isolated structures. Structures in which the first mode damping exceeds 20% or 30% typically do not exhibit classical modes, and simulation via a simple superposition of uncoupled second order equations is not possible. When the damping is produced by viscous or linear visco-elastic devices, we can, however, gain insight into the dynamic behavior of these structures using a convenient first-order formulation and frequency domain methods. When the damping effects are created by nonlinear mechanisms such as yielding or friction, the behavior of the structure is amplitude dependent and analyses are commonly carried out in the time domain. In this paper, frequency domain analysis and earthquake time history analysis are applied to study the influence of isolation damping on higher-mode effects and inter-story drift ratios. Because higher mode effects, plan irregularities, and bi-directional ground motions are all important attributes of the dynamic behavior of these structural systems, a simple comparison of isolation damping mechanisms can not be carried out via simple single or two degree of freedom realizations. In order to incorporate these important details in the study of the dynamic behavior of these structures, a set of 8-story proto-type building models with L-shaped floor plans, different isolation periods, isolation damping characteristics, and levels of isolation stiffnesses are examined.
  • malc, vardan, jcbv, sodapas, kowheng, mgdario
  Seismic Retrofitting of Historic Masonry Buildings – Case Study Grunf 3 9,207 05-26-2016, 03:19 AM
Last Post: gulilero
  Non-Linear Seismic Response of Base-Isolated Frame Structures Using Rubber Bearings TAFATNEB 0 4,801 12-26-2014, 09:49 PM
  RESPONSE ANALYSIS STUDY OF A BASE-ISOLATED BUILDING BASED ON SEISMIC CODES WORLDWIDE TAFATNEB 0 4,148 08-10-2014, 01:15 PM
  SEISMIC RETROFIT STUDY OF CABLE-STAYED BRIDGE ON TOKYO-GAIKAN EXPRESSWAY TAFATNEB 0 3,352 05-02-2014, 08:58 AM
  Non-linear viscoelastic modelling of earthquake-induced structural pounding TAFATNEB 0 2,930 04-23-2014, 03:37 PM
  Seismic performance of a 12-storey ductile concrete shear wall system designed accord TAFATNEB 0 3,809 04-21-2014, 10:41 PM
  Analytical Case Study of Seismic Performance of Retrofit Strategies for Reinforced Co TAFATNEB 0 3,660 04-17-2014, 10:21 AM
