Civil Engineering Association eBooks Journals, Papers and Presentations RESPONSE ANALYSIS STUDY OF A BASE-ISOLATED BUILDING BASED ON SEISMIC CODES WORLDWIDE
08-10-2014, 01:15 PM
Author: Demin Feng , Tian-Chyuan Chan , and Shuguang Wang , Hsi-Yun Chen and Yaw-Nan Chang | Size: 424 KB | Format: PDF | Quality: Unspecified | Publisher: 4th International Conference on Earthquake Engineering Taipei, Taiwan October 12-13, 2006 | Year: 2006 | pages: 09
[Image: 48169107810005348757.jpg]
The procedures to do response analysis of a seismically isolated building are summarized based on the building codes of Japan, China, the USA, Italy and Taiwan. While a dynamic response analysis method is recommended in all five building codes, a simplified design procedure based on equivalent linear analysis is also permitted under limited conditions. Subsequently, a typical 14-story reinforced concrete building, isolated with lead-rubber bearings is analyzed using each of the five building codes. The average response values are taken as design values to compare with the results by the equivalent linear analysis method. The deformation of the isolation level and the base shear force coefficient of the superstructure are compared. Finally, the response reduction factor defined in the Japanese code is applied to the other four building codes to improve the accuracy of equivalent linear analysis results.
  • vardan, ting tsai huang, jcbv, blaze, amindoxiti, chenamoy, zrilek, Mohammad6299, malc, ruaumoko, civilgen
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 12,314 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Seismic Retrofitting of Historic Masonry Buildings – Case Study Grunf 3 10,294 05-26-2016, 03:19 AM
Last Post: gulilero
  Performance-based seismic assessment of skewed bridges bridgeengineer 0 5,126 04-22-2016, 06:31 AM
Last Post: bridgeengineer
  Responses of isolated building with MR Dampers and Fuzzy Logic TAFATNEB 0 5,073 12-28-2014, 08:57 AM
  Non-Linear Seismic Response of Base-Isolated Frame Structures Using Rubber Bearings TAFATNEB 0 5,831 12-26-2014, 09:49 PM
  Response and Analysis of a Large Diameter Drilled Shaft Subjected to Lateral Loading mybest 1 5,826 10-21-2014, 08:57 AM
Last Post: Munykong
  Evaluation Of Earthquake Response Analysis Methods For Low - Rise Base Isolated B. TAFATNEB 0 5,860 09-05-2014, 01:46 PM
