Civil Engineering Association eBooks Journals, Papers and Presentations Non-Linear Seismic Response of Base-Isolated Frame Structures Using Rubber Bearings
Likes: 9,406 in 1,160 posts
12-26-2014, 09:49 PM (This post was last modified: 12-27-2014, 12:07 AM by oanm2000.)
Author: Anis S. Shatnawi , Abdelqader S. Najmv) , Mu’tasim S. Abdel-Jaberv) and Iyad M. Amareen | Size: 0.6 MB | Format: PDF | Quality: Unspecified | Publisher: Jordan Journal of Civil Engineering, Volume 2, No. 2, 2008 | Year: 2008 | pages: 20
Over the past two decades, much progress has been made in research and application of the base isolation of structures as means of providing earthquake resistance to a structure. However, the trade-off between the extent of acceleration reduction and the response of a base-isolation system has not been given a serious consideration.
This work uses a new material constitutive model for rubber bearing base-isolation system, which adopts the technique of real-time structural parameter modification. To achieve this, a finite element modeling and analysis are performed as a comparative study between a conventional totally fixed-base steel frame structure and similar base-isolated structures using rubber-steel bearings. The structures are subjected to the El-Centro, N-S earthquake.
In order to include nonlinearity effects, a non-linear hyperviscoelastic material model has been used and linked to ABAQUS software as a user defined material subroutine (i.e., UMAT). Special connector elements are selected from ABAQUS library to connect the rubber bearings to the frame structure and the foundations in order to achieve the required kinematical constraints at the connection points. The model is validated by carrying out a comparative study of the results obtained from the analysis of the presented material model with those obtained by using the existing ABAQUS material models (e.g., Ogden material model). The results show a significance efficiency of using the rubber bearing isolation in order to uncouple the structure from the seismic ground motion. Moreover, it has been proved that the used material model is more effective to capture the behavior of the base-isolated structures expressing a notable reduction in acceleration and an increase in the structural resistance to earthquake excitations.
[-] The following 16 users Like TAFATNEB's post:16 users Like TAFATNEB's post
  • vardan, rezart, oanm2000, malc, zrilek, blaze, PinkPant, jcbv, slowet, SCREAM7890, bridgeengineer, cace-01, terrorruban, civilgen, Clouseau, 19326
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 0 5,835 10-08-2014, 02:06 PM
  Evaluation of Egyptian code provisions for seismic design of moment-resisting-frame m TAFATNEB 0 4,752 09-05-2014, 02:03 PM
  Seismic performance of concrete frame structures reinforced with superelastic shape TAFATNEB 0 5,783 09-05-2014, 01:59 PM
  Evaluation Of Earthquake Response Analysis Methods For Low - Rise Base Isolated B. TAFATNEB 0 5,600 09-05-2014, 01:46 PM
  Pounding between base-isolated and fixed-base RC buildings during earthquakes TAFATNEB 0 3,838 08-14-2014, 07:52 AM
  Experimental studies of the ultimate behavior of seismically-isolated structures arshiakh 0 4,124 08-13-2014, 03:37 PM
Last Post: arshiakh
  Seismic response of earth dams: some recent developments TAFATNEB 0 3,980 08-12-2014, 09:33 AM
