Civil Engineering Association eBooks Journals, Papers and Presentations Seismic performance of concrete frame structures reinforced with superelastic shape
Likes: 9,406 in 1,160 posts
09-05-2014, 01:59 PM (This post was last modified: 09-06-2014, 09:24 AM by lisine.)
Seismic performance of concrete frame structures reinforced with superelastic shape memory alloys
Author: M. Shahria Alam, Moncef Nehdi* and Maged A. Youssef | Size: 03 MB | Format: PDF | Quality: Unspecified | Publisher: Smart Structures and Systems, Vol. 5, No. 5 (2009) 565-585 | Year: 2009 | pages: 21
Abstract. Superelastic Shape Memory Alloys (SMAs) are gaining acceptance for use as reinforcing bars in
concrete structures. The seismic behaviour of concrete frames reinforced with SMAs is being assessed in this
study. Two eight-storey concrete frames, one of which is reinforced with regular steel and the other with SMAs at
the plastic hinge regions of beams and regular steel elsewhere, are designed and analyzed using 10 different
ground motion records. Both frames are located in the highly seismic region of Western Canada and are designed
and detailed according to current seismic design standards. The validation of a finite element (FE) program that
was conducted previously at the element level is extended to the structure level in this paper using the results of a
shake table test of a three-storey moment resisting steel RC frame. The ten accelerograms that are chosen for
analyzing the designed RC frames are scaled based on the spectral ordinate at the fundamental periods of the
frames. The behaviour of both frames under scaled seismic excitations is compared in terms of maximum interstorey
drift, top-storey drift, inter-storey residual drift, and residual top-storey drift. The results show that SMA-
RC frames are able to recover most of its post-yield deformation, even after a strong earthquake.
  • cace-01, vardan, zrilek, malc, blaze
  Experiment and Analysis on X-Shaped Reinforced Concrete Joint in Diagrid Structures asim99 1 5,881 04-20-2018, 05:19 PM
Last Post: munycamsec
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 11,974 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Performance-based seismic assessment of skewed bridges bridgeengineer 0 4,905 04-22-2016, 06:31 AM
Last Post: bridgeengineer
  Seismic evaluation of a 56-storey residential reinforced concrete high-rise building anfaga 3 8,435 02-10-2016, 02:49 PM
  2nd ATC-SEI Conference on Improving the Seismic Performance of Existing Buildings and RyanRS 0 5,004 10-29-2015, 12:55 AM
Last Post: RyanRS
  Assessment of the seismic performance of a bituminous faced rockfill dam Wolverine883 0 5,649 07-19-2015, 07:24 AM
Last Post: Wolverine883
  Seismic Design of Concrete Structures - The Present Needs of Societies RyanRS 0 5,301 05-17-2015, 05:49 AM
Last Post: RyanRS
