Civil Engineering Association eBooks Journals, Papers and Presentations Experiment and Analysis on X-Shaped Reinforced Concrete Joint in Diagrid Structures
 asim99
User ID: 9774
Threads: 476
Likes: 6,384 in 594 posts
Given Likes: 377
03-16-2013, 11:02 PM (This post was last modified: 04-20-2018, 08:42 PM by oanm2000.)
Author: Wei Zhou, Jianxin Zhang, and Zhenggang Cao | Size: 3 MB | Format: PDF | Quality: Unspecified | Publisher: ACI | Year: 2013 | pages: 12
[Image: 46254957570275053170.jpg]
Diagrid tube structures are expected to be used for the outer tubes of super tall tube-in-tube buildings. The mechanical behavior and design method of X-shaped reinforced concrete joints, which are formed by four crossed inclined columns and horizontal girders, are important issues in the design and analysis of vertical crossing lattice tube. Taking the volumetric ratio of the stirrup and the loading pattern as fundamental parameters, four X-shaped reinforced concrete joints were designed and subjected to static axial load testing. The test phenomenon—including deformation of joint zones, development of cracks, and crushing of concrete— is strongly emphasized in the analysis. The laws of the stiffness response and stress development in longitudinal bars and stirrups are revealed, and the ultimate load-bearing capacity of four joints is obtained. The test results show that the stirrups may confine the lateral expanding deformation of the joint concrete regions.
The X-shaped reinforced concrete joints with normal volumetric ratios of stirrups may be designed to provide large stiffness and high load-bearing capacity, which are also effective in transmitting the inner force from four crossed inclined columns. Adopting two loading patterns—agreeing and differential loads—on four inclined columns has little influence on the load-bearing capacity of the joints. Based on the results of the test and analysis, design recommendations and formulas of the bearing capacity for X-shaped reinforced concrete joints in vertical crossing lattice structures are proposed.
[-] The following 16 users Like asim99's post:16 users Like asim99's post
  • Dell_Brett, ruaumoko, ting tsai huang, kowheng, Jackass, malc, eRw1n, maad59, subin91, knrsa, stigtg, ssobhan, ibg0203, gulilero, warbeast, munycamsec
 munycamsec
Cambodia
User ID: 175583
Threads: 1
Likes: 7 in 2 posts
Given Likes: 244
04-20-2018, 05:19 PM
Please new link, the link above not valid
  NONLINEAR ANALYSIS FOR A REINFORCED CONCRETE FRAME STRUCTURE UNDER EXTREME LOADS TAFATNEB 0 5,990 11-15-2014, 02:07 PM
  Seismic performance of concrete frame structures reinforced with superelastic shape TAFATNEB 0 5,990 09-05-2014, 01:59 PM
  Nonlinear Analysis of a Collapsed Reinforced Concrete Chimney TAFATNEB 0 4,150 08-10-2014, 02:59 PM
  A NEW MODEL FOR JOINT SHEAR FAILURE OF REINFORCED CONCRETE INTERIOR BEAM-TO-COLUMN JO TAFATNEB 0 3,878 06-01-2014, 03:35 PM
  Dynamic Analysis of Reinforced Concrete Building with Plan Irregularities TAFATNEB 0 4,590 05-30-2014, 01:43 PM
  Pushover Analysis of 4 Storey’s Reinforced Concrete Building TAFATNEB 0 4,681 04-09-2014, 06:14 PM
  SEISMIC RETROFIT OF REINFORCED CONCRETE BRIDGES WITH FIBER REINFORCED POLYMER COMPOSI TAFATNEB 0 4,559 04-03-2014, 12:26 PM
