Civil Engineering Association eBooks Journals, Papers and Presentations NONLINEAR ANALYSIS FOR A REINFORCED CONCRETE FRAME STRUCTURE UNDER EXTREME LOADS
Likes: 9,403 in 1,160 posts
Given Likes: 2855
Points:118,565 EP
11-15-2014, 02:07 PM
Author: Cătălin BACIU , Marin LUPOAE | Size: 1.3 MB | Format: PDF | Quality: Unspecified | Publisher: CONSTRUCŢII – No. 1 / 2012 | Year: 2012 | pages: 11
[Image: 62227728629402873218.jpg]
Terrorist actions of the last decade obviously determine a reconsideration of the buildings safety, especially for those with special destinations (embassies, military facilities, nuclear plants etc.). Thus, the conception phase should include nowadays scenarios with exceptional actions, other than seismic loads:
impact, explosion, failure of supports. It is well-known that, after earthquakes, the most situations of structural collapse are determined by the terrorist attack using explosive. Even
more, it has been assessed that the main reason of loss of life is not the explosion itself, but the partial or total collapse of the exposed building. In order to secure the structural integrity,
collapse analysis should be taken into account as a complex phenomenon, composed of many processes that could be studied separately or as an ensemble. These processes are: the extreme action causes, design requirements, vulnerability
of the structure, starting and development of the collapse, its final effects. Study of these processes leads to additional special measures for design stage and, on the other hand, to valuable knowledge for controlled demolition of tall buildings, as part of bold urbanism projects in densely populated zones. Considering the above mentioned facts, this paper presents the results of a thorough analysis of a frame structure under explosive loads. The first part of the paper refers to the analysis of a phenomena assembly related to explosion and to the effects resulting from a terrorist attack using explosives (structural elements deterioration and failure, collapse initiation and eventual total failure). The second part of the paper presents an original approach to analyze a building structure
under extreme loads, using both classical (pushover) and modern (applied element method).
  • amindoxiti, vardan, Quantumm, cace-01, blaze, gulilero, zrilek, malc, ykhackhack, bridgeengineer, promo8, sodapas, temp1366
  Experiment and Analysis on X-Shaped Reinforced Concrete Joint in Diagrid Structures asim99 1 4,791 04-20-2018, 05:19 PM
Last Post: munycamsec
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 10,069 08-01-2017, 09:19 AM
Last Post: abdulazizk
  BEHAVIOR OF FIBER-REINFORCED POLYMER (FRP) COMPOSITE PILES UNDER VERTICAL LOADS ir_71 1 5,470 06-01-2015, 05:11 PM
  Soil-Structure Interaction of Retaining Walls under Earthquake Loads TAFATNEB 0 4,462 12-26-2014, 10:12 PM
  Seismic performance of concrete frame structures reinforced with superelastic shape TAFATNEB 0 4,461 09-05-2014, 01:59 PM
  Nonlinear Analysis of a Collapsed Reinforced Concrete Chimney TAFATNEB 0 3,102 08-10-2014, 02:59 PM
  Dynamic Analysis of Reinforced Concrete Building with Plan Irregularities TAFATNEB 0 3,571 05-30-2014, 01:43 PM
