Civil Engineering Association eBooks Journals, Papers and Presentations Dynamic stiffness of foundation on layered soil half-space using cone frustums
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
Points:46,589 EP
09-19-2012, 02:51 PM
Author: John P. Wolf, Jethro W. Meek2 | Size: 1 MB | Format: PDF | Quality: Original preprint | Publisher: Wiley Online Library | Year: 1994 | pages: 17
Approximate dynamic-stiffness coefficients of a disk on the surface of a single layer on a half-space may be calculated using cone models. This concept is generalized to the case of a horizontally stratified site consisting of many layers on a homogeneous half-space. After constructing the so-called ‘backbone cone’ determining the radii of the disks at all interfaces, the dynamic-stiffness matrices of the layers (modelled as cone frustums) and the dynamic-stiffness coefficient of the underlying half-space (modelled as a cone) are assembled to that of the site. The dynamic-stiffness matrix of a layer is a complex-valued function of frequency because radiation of energy in the horizontal direction is considered. In this model of the layered half-space the properties of the cone reproduce themselves (cloning). The advantages of using cone models are also present for the layered half-space; in particular, no transformation to the wave-number domain is performed.
[-] The following 7 users Like mybest's post:7 users Like mybest's post
  • warlord1, cace-01, 3fan, zrilek, kowheng, Dell_Brett, marove
  Influence of foundation stiffness on vibrations of rotor systems TAFATNEB 0 3,482 08-11-2014, 10:54 AM
  Evaluation of dynamic properties of site and Response of Motion Si mulator Foundation TAFATNEB 0 3,746 08-11-2014, 10:49 AM
  Dynamic Stiffness and Damping of a Shallow Foundation from Forced Vibration of a Fiel TAFATNEB 0 3,380 08-11-2014, 10:20 AM
  Seismic evaluation of fluid-elevated tank-foundation/soil systems in frequency domain TAFATNEB 0 3,771 05-10-2014, 08:32 AM
  DYNAMIC RESPONSE OF CIRCULAR PLATES ON ELASTIC FOUNDATION SUBJECTED TO SONIC BOOMS TAFATNEB 0 3,434 10-25-2013, 03:44 PM
  DYNAMIC PILE-SOIL-PILE INTERACTION. PART I: ANALYSIS OF AXIAL VIBRATION TAFATNEB 0 3,525 08-30-2013, 10:54 PM
  Dynamic stability of cracked columns; the stiffness reduction method asim99 0 3,909 05-11-2013, 06:06 PM
Last Post: asim99
