Strength reduction FEM in stability analysis of soil slopes subjected to transient un
Strength reduction FEM in stability analysis of soil slopes subjected to transient unsaturated seepage
Author: Maosong Huang, Cang-Qin Jia | Size: 464 KB | Format: PDF | Quality: Unspecified | Publisher: Computers and Geotechnics | Year: 2009 | pages: 9
The instability of soil slopes induced by the fluctuation of water level or rainfall has received much attention in the literature recently and the failure mechanism is closely related to the change of matric suction of unsaturated soils. Such a change is basically induced by unsaturated transient seepage. The traditional approach for estimating the stability of slopes subjected to unsaturated transient seepage is based on the limit equilibrium method (LEM). The limit equilibrium approach is limited by assumptions about analysis method and failure mechanism. In order to overcome those limitations, a finite element method with shear strength reduction technique (SSRFEM) has been successfully applied to the slope stability analysis in absence of seepage. The main objective of this paper is to extend the use of the strength reduction FEM to include the effects of unsaturated transient seepage and some primary numerical results concerning the stability of an earth dam under rapid drawdown are presented. Emphasis has been given to comparison of the safety factors obtained by LEM and SSRFEM. Topics for the further research in this area are also suggested.
PinkPant
[-] The following 6 users say Thank You to PinkPant for this post:
  • freequo, zrilek, amindoxiti, blaze, malc, ykhackhack
Response and Analysis of a Large Diameter Drilled Shaft Subjected to Lateral Loading mybest 1 2,044 10-21-2014, 09:57 AM
Last Post: Munykong
Application of soil nailing for slope stability purpose - UTS Student Final Project robertsas 2 3,141 05-17-2014, 05:11 PM
Last Post: Mohammad6299
FINITE ELEMENT ANALYSIS OF BASE ISOLATED BUILDINGS SUBJECTED TO EARTHQUAKE LOADS TAFATNEB 1 1,564 11-20-2013, 08:25 AM
Empirical Correlations: Drained Shear Strength for Slope Stability Analyses asim99 0 1,509 06-15-2013, 05:46 PM
Last Post: asim99
Dynamic stability of cracked columns; the stiffness reduction method asim99 0 1,342 05-11-2013, 07:06 PM
Last Post: asim99
