Investigation of progressive collapse in intermediate RC frame structures
Author: Alireza Pachenari, Abolghassem Keramati and Zahra Pachenari | Size: 370 KB | Format: PDF | Quality: Unspecified | Publisher: Wiley | Year: 2010 | pages: 10
A large part of common reinforced concrete (RC) structures are designed as intermediate moment resisting
frames. However, current progressive collapse studies have not paid much attention to these frames. In this
study, based on the acceptance criteria of the UFC 4-023-03 document, the infl uence of some external and
corner column removal cases are evaluated by nonlinear procedures in all storeys of a regular structure.
Although this structure considers the acceptance criteria of nonlinear dynamic analyses, nonlinear static
analyses require additional reinforcement in beam supports in the top two storeys. Compared to dynamic
analyses, it is also concluded that static analyses are more conservative in the estimation of maximum
vertical displacement and shear force in beams.
a- Follow the Forum Rules.
[-] The following 1 user says Thank You to asim99 for this post:
  • malc
Progressive collapse analysis of an RC building with exterior partially infilled wall asim99 1 1,669 03-01-2017, 05:02 PM
Last Post: pezhmankhan
Earthquake-Induced Collapse Simulation of a Super-Tall Mega-Braced Frame-Core Tube Bu TAFATNEB 0 2,224 07-05-2015, 12:37 PM
Progressive Collapse of Multi-Storey Buildings due to Sudden Column Loss –Part II: Ap TAFATNEB 0 1,178 05-09-2014, 03:00 PM
Retrofit Methods to Mitigate Progressive Collapse TAFATNEB 0 1,564 05-09-2014, 12:44 PM
Progressive Collapse of Bridges—As pects of Analysis and Design TAFATNEB 0 1,051 05-02-2014, 10:02 AM
