Civil Engineering Association eBooks Journals, Papers and Presentations Progressive collapse analysis of an RC building with exterior partially infilled wall
 asim99
User ID: 9774
Threads: 476
Likes: 6,384 in 594 posts
Given Likes: 377
05-04-2013, 02:55 AM (This post was last modified: 03-01-2017, 07:25 PM by oanm2000.)
Progressive collapse analysis of an RC building with exterior partially infilled walls
Author: Meng-Hao Tsai and Tsuei-Chiang Huang | Size: 1.61 MB | Format: PDF | Quality: Unspecified | Publisher: Wiley | Year: 2011 | pages: 22
Exterior partially infi lled walls of RC condominium buildings are often monolithically cast with beams and/or columns in Taiwan. In practice, they are regarded as non-structural elements in usual structural design, and only their weight is conservatively considered. In this study, effects of three common types of exterior partially infi lled walls on the progressive collapse potential of an RC building are investigated.
Linear and nonlinear static analyses under different column-loss scenarios are carried out. Analysis results indicate that infl uence of the partially infi lled walls differs from each type. Changes in the demand-tocapacity ratios indicate that without considering the walls, the moment demand of beams may be overestimated.
However, their shear demand may be underestimated, especially with the panel-type walls. Meanwhile, they may increase the collapse resistance of the building frame under column loss but with decreased ductility capacity. From the structural aspect, with a constant opening rate of 60%, the wing-type wall is a better option than the parapet- and panel-type walls. The panel-type wall appears to be the worst choice since shear failure of their connected beam members may be induced.
[-] The following 3 users Like asim99's post:3 users Like asim99's post
  • malc, zrilek, K.Lee
Likes: 12,071 in 1,233 posts
03-01-2017, 04:02 PM
[-] The following 7 users Like pezhmankhan's post:7 users Like pezhmankhan's post
  • blaze, amindoxiti, oanm2000, Dell_Brett, zrilek, subin91, K.Lee
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 12,071 08-01-2017, 09:19 AM
Last Post: abdulazizk
  CTV Building Collapse - NLTHA Report - Christchurch Earthquake 2011 jamesmakeez 0 4,506 10-28-2016, 03:23 AM
Last Post: jamesmakeez
  Progressive Collapse of Multi-Storey Buildings due to Sudden Column Loss –Part II: Ap TAFATNEB 0 4,734 05-09-2014, 02:00 PM
  Retrofit Methods to Mitigate Progressive Collapse TAFATNEB 0 4,650 05-09-2014, 11:44 AM
  SIMULATION TECHNIQUES FOR COLLAPSE ANALYSIS OF RC BRIDGE UNDER STRONG EARTHQUAKE TAFATNEB 0 4,125 05-03-2014, 09:39 AM
  Progressive Collapse of Bridges—As pects of Analysis and Design TAFATNEB 0 4,172 05-02-2014, 09:02 AM
  Seismic collapse analysis on core-outrigger structures TAFATNEB 0 3,595 04-26-2014, 11:15 AM
