Civil Engineering Association eBooks Journals, Papers and Presentations Progressive Collapse of Multi-Storey Buildings due to Sudden Column Loss –Part II: Ap
Likes: 9,404 in 1,160 posts
Points:118,565 EP
05-09-2014, 02:00 PM
Progressive Collapse of Multi-Storey Buildings due to Sudden Column Loss –Part II: Application
Author: A.G. Vlassis , B.A. Izzuddin , A.Y. Elghazouli , D.A. Nethercot | Size: 2.2 MB | Format: PDF | Quality: Unspecified | pages: 43
[Image: 94763722321515889600.jpg]
The companion paper presents the principles of a new design-oriented methodology for progressive
collapse assessment of multi-storey buildings. The proposed procedure, which can be implemented at
various levels of structural idealisation, determines ductility demand and supply in assessing the
potential for progressive collapse initiated by instantaneous loss of a vertical support member. This
paper demonstrates the applicability of the proposed approach by means of a case study, which
considers sudden removal of a ground floor column in a typical steel-framed composite building. In
line with current progressive collapse guidelines for buildings with a relatively simple and repetitive
layout, the two principal scenarios investigated include removal of a peripheral column and a corner
column. The study shows that such structures can be prone to progressive collapse, especially due to
failure of the internal secondary beam support joints to safely transfer the gravity loads to the
surrounding undamaged members if a flexible fin plate joint detail is employed. The provision of
additional reinforcement in the slab over the hogging moment regions can generally have a beneficial
effect on both the dynamic load carrying and deformation capacities. The response can be further
improved if axial restraint provided by the adjacent structure can be relied upon. The study also
highlights the inability of bare-steel beams to survive column removal despite satisfaction of the code
prescribed structural integrity provisions. This demonstrates that tying force requirements alone cannot
always guarantee structural robustness without explicit consideration of ductility demand/supply in the
support joints of the affected members, as determined by their nonlinear dynamic response.
  • vardan, ting tsai huang, zrilek, rezart, jcbv, blaze, malc, slowet, milova
  Progressive collapse analysis of an RC building with exterior partially infilled wall asim99 1 6,157 03-01-2017, 04:02 PM
Last Post: pezhmankhan
  POST-TENSIONED CONCRETE FLOORS IN MULTI-STOREY BUILDINGS ir_71 4 9,814 04-23-2015, 09:15 AM
Last Post: titko
  Retrofit Methods to Mitigate Progressive Collapse TAFATNEB 0 4,528 05-09-2014, 11:44 AM
  Vulnerability of buildings to windstorms and insurance loss estimation TAFATNEB 0 3,307 05-09-2014, 10:30 AM
  Progressive Collapse of Bridges—As pects of Analysis and Design TAFATNEB 0 4,035 05-02-2014, 09:02 AM
  VULNERABILITY TO PROGRESSIVE COLLAPSE OF SEISMICALLY DESIGNED RC FRAMED STRUCTURES: C TAFATNEB 0 4,022 04-26-2014, 10:22 AM
  Static pushover versus dynamic collapse analysis of RC buildings TAFATNEB 1 4,423 11-25-2013, 07:32 AM
