Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS C4.2/C4.2M: Recommended Practices for Oxyfuel Gas Cutting Torch Operation
08-30-2023, 08:22 AM
AWS C4.2/C4.2M-2017: Recommended Practices for Oxyfuel Gas Cutting Torch Operation
| Size: 5.16 MB| Format: PDF| Quality: Scanner| Year: 3rd Edition, 2017| pages: 50
[Image: 04003409458087393276.png]
AWS C4.2/C4.2M, 3rd Edition, 2017 - Recommended Practices for Oxyfuel Gas Cutting Torch Operation
This standard describes the equipment, procedures, and safe practices for the oxyfuel cutting of steel. It is for the operators of both hand and machine torches and is recommended for management personnel associated with the oxyfuel cutting process.
Oxyfuel gas cutting is a process whereby a metal (usually an iron base alloy) is heated to its kindling temperature (well below the melting point) by an oxyfuel gas flame and then burned rapidly by a regulated jet of oxygen. A cutting torch is used for this operation. Although this recommended practice is not written with mandatory requirements, mandatory language, such as the use of “shall,” will be found in those portions of the document where failure to follow the instructions or procedures could produce inferior, misleading, or unsafe results.
  • PinkPant, babakfeyzi, rami1976, kowheng
  AWS C3.11M/C3.11: Specification for Torch Soldering poolmand 1 3,173 05-29-2024, 11:05 AM
  AWS D14.7/D14.7M: Recommended Practices for Surfacing and Reconditioning of Industria poolmand 0 1,402 09-09-2023, 12:52 PM
  AWS D10.10/D10.10M: Recommended Practices for Local Heating of Welds in Piping and Tu poolmand 0 1,459 09-04-2023, 11:44 AM
  AWS D10.8: Recommended Practices for Welding of Chromium-Molybdenum Steel Piping and poolmand 0 1,685 09-04-2023, 11:40 AM
  AWS D10.6/D10.6M: Recommended Practices for Gas Tungsten Arc Welding of Titanium Pipe poolmand 0 1,358 09-04-2023, 11:35 AM
  AWS C7.2M: Recommended Practices for Laser Beam Welding, Cutting, and Allied Processe poolmand 0 1,451 09-02-2023, 09:39 AM
  AWS C7.1M/C7.1: Recommended Practices for Electron Beam Welding and Allied Processes poolmand 0 1,472 09-02-2023, 09:36 AM
