Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS D10.10/D10.10M: Recommended Practices for Local Heating of Welds in Piping and Tu
09-04-2023, 11:44 AM
AWS D10.10/D10.10M-2021: Recommended Practices for Local Heating of Welds in Piping and Tubing
| Size: 38.19 MB| Format: PDF| Quality: Scanner| Year: 4th Edition, 2021| pages: 124
[Image: 21248262247691617923.jpg]
These recommended practices describe several methods of applying controlled heat to weld joints and a limited volume of base metal adjacent to the joints, as opposed to heating the complete weldment in a furnace or oven. Additional criteria (e.g., thermocouple requirements, temperature requirements, heat placement) may be required for Creep Strength-Enhanced Ferritic (CSEF) Steels. The applicable code or standard shall take precedence in the event of conflict with this standard.
The primary purpose for the requirements in this document is to ensure that the root of the weld at the inside diameter (ID) of the pipe or tube achieves minimum postweld heat treatment (PWHT) temperature.
  • jcbv, PinkPant, babakfeyzi, kowheng
  AWS F4.1: SAFE PRACTICES FOR THE PREPARATION OF CONTAINERS AND PIPING FOR WELDING, CU poolmand 0 1,451 01-22-2024, 11:20 AM
  AWS D14.7/D14.7M: Recommended Practices for Surfacing and Reconditioning of Industria poolmand 0 1,421 09-09-2023, 12:52 PM
  AWS D10.22/D10.22M: SPECIFICATION FOR LOCAL HEATING OF WELDS IN CREEP STRENGTH-ENHANC poolmand 0 1,546 09-04-2023, 12:05 PM
  AWS D10.8: Recommended Practices for Welding of Chromium-Molybdenum Steel Piping and poolmand 0 1,705 09-04-2023, 11:40 AM
  AWS D10.6/D10.6M: Recommended Practices for Gas Tungsten Arc Welding of Titanium Pipe poolmand 0 1,369 09-04-2023, 11:35 AM
  AWS C7.2M: Recommended Practices for Laser Beam Welding, Cutting, and Allied Processe poolmand 0 1,466 09-02-2023, 09:39 AM
  AWS C7.1M/C7.1: Recommended Practices for Electron Beam Welding and Allied Processes poolmand 0 1,482 09-02-2023, 09:36 AM
