Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis SEISMIC PERFORMANCE ASSESSMENT OF REINFORCED CONCRETE BUILDINGS WITH PRECAST CONCRETE
03-27-2015, 03:16 PM
SEISMIC PERFORMANCE ASSESSMENT OF REINFORCED CONCRETE BUILDINGS WITH PRECAST CONCRETE FLOOR SYSTEMS
Author: Brian Hsuan-Hsien PENG | Size: 9.8 MB | Format: PDF | Quality: Unspecified | Publisher: UNIVERSITY OF CANTREBURY | Year: 2009 | pages: 495
[Image: 00657603397388640761.png]
In the seismic design of reinforced concrete frames, plastic hinges are allocated to beams such that a ductile beam-sway mechanism will form in preference to other less
ductile mechanisms in the event of a major earthquake. This is achieved by ensuring that the flexural strength of columns is greater than that corresponding to the maximum likely flexural strength of beam plastic hinges. Recent experimental studies in New Zealand have shown that elongation of ductile beam plastic hinges, and its interaction with nearby floor slab containing precast- prestressed floor units, increases the strength of beams much more than that specified in New Zealand and American Concrete standards. This level of strength enhancement has raised concern on the adequacy of the current design provisions. To further investigate this problem, a research project was initiated to examine the
strength of beam plastic hinges in reinforced concrete frames containing precast- prestressed floor units. In this research, the strength of beam plastic hinges was assessed through
experimental and analytical studies. A three-dimensional, one-storey, two-bay reinforced concrete moment resisting frame with prestressed floor units and cast-in- situ concrete topping was tested under quasi-static displacement-controlled cyclic loading. The experimental results provided insight into the mechanics associated with frame-floor interaction. Subsequently, improved design specifications were proposed based on the observed behaviour. To analytically predict the beam-floor interaction, a ductile reinforced concrete plastic hinge multi-spring element was developed and validated with experimental results from cantilever beam and frame sub-assembly tests reported in the literature. The comparisons have demonstrated the ability of the proposed plastic hinge element to predict the flexural, shear, axial, and most importantly, elongation response of ductile plastic hinges.
  • rezart, zrilek, jcbv, ruaumoko, oanm2000, inge911, simanta, cace-01, chenamoy, melekeen, PinkPant, malc, mgdario
  Non-linear analysis of a collapsed reinforced concrete chimney mybest 1 3,884 11-06-2020, 08:17 AM
  The Seismic Analysis of Statically Designed Tall Reinforced Concrete Buildings Using bridgeengineer 0 2,967 04-20-2016, 09:31 AM
Last Post: bridgeengineer
  Seismic Performance Assessment and Probabilistic Repair Cost Analysis of Precast Conc TAFATNEB 0 1,597 07-03-2015, 10:30 PM
  Inelastic seismic response of precast concrete large panel coupled shear wall sys TAFATNEB 0 1,811 03-27-2015, 11:44 AM
  Performance Based Approach in Seismic Design of Embedded Retaining Walls TAFATNEB 0 1,935 02-09-2015, 07:24 AM
  Assessment of Progressive Collapse Requirements for Precast Concrete Buildings TAFATNEB 0 1,860 12-13-2014, 05:08 PM
  Analysis and modelling of the seismic behaviour of high d u ctility steel-concrete co TAFATNEB 0 1,797 09-02-2014, 08:10 AM
