Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Assessment of Progressive Collapse Requirements for Precast Concrete Buildings
12-13-2014, 05:08 PM
Author: Feng Shi | Size: 04 MB | Format: PDF | Quality: Unspecified | Year: 2011 | pages: 149
[Image: 62353296898884428366.jpg]
Threat evaluations due to bombing and progressive collapse of precast concrete building systems are examined and presented in this report. A prototype structure based on the moment frame building system from PCI-Seismic Design for Precast/Prestressed Concrete Structures is used for these evaluations. Two distinct studies are conducted. The first examines the potential for abrupt failure of the ground level columns due to intentional detonation of explosives; the second examines the potential for progressive collapse of the building system as a result of this loss. Three types of column failures, including brisance failure, flexural failure, and direct shear failure are discussed and evaluated based on blast oad effects. For each failure case, the number of failed columns respect to stand-off ranges
with specified weight of charges is determined by employing UFC-3-340-02. A pictorial representation of the stand-off distances and number of failed columns are provided to assess the combined effects of blast load types with a specified charge weight. The generalized image provides a safe-range for each failure type. This methodology can be used to guide engineers in making enhancement to columns based or safe standoff ranges to ensure that safe operating levels are satisfied. In progressive collapse analysis section, the structure is examined using the procedures of the Unified Facilities Criteria (UFC) and the General Services Administration (GSA). Three model cases are compared: original model, modified model with cantilever continuous beam, and modified model with fixed-fixed continuous beam, analyze progressive collapse responses and make modifications by employing linear static procedure. The current GSA progressive collapse guidelines and UFC progressive collapse design are used for evaluations, and the commercially available structural analysis program ETABS Nonlinear V9.7.1 is utilized to perform example analyses.
[-] The following 14 users Like TAFATNEB's post:14 users Like TAFATNEB's post
  • gulilero, vardan, zrilek, amindoxiti, bridgeengineer, oanm2000, malc, Dell_Brett, blaze, Andrew seah, PinkPant, mgdario, sodapas, ruaumoko
  Alternate Path method in progressive collapse analysis hich 2 4,274 03-27-2020, 09:58 PM
Last Post: sabooryan
  Seismic Performance Assessment and Probabilistic Repair Cost Analysis of Precast Conc TAFATNEB 0 1,580 07-03-2015, 10:30 PM
  SEISMIC PERFORMANCE ASSESSMENT OF REINFORCED CONCRETE BUILDINGS WITH PRECAST CONCRETE TAFATNEB 0 1,882 03-27-2015, 03:16 PM
  Inelastic seismic response of precast concrete large panel coupled shear wall sys TAFATNEB 0 1,798 03-27-2015, 11:44 AM
  COLLAPSE ASSESSMENT OF CONCRETE BUILDINGS: AN APPLICATION TO NON-DUCTILE REINFORCED C TAFATNEB 0 1,674 12-28-2013, 08:59 PM
  Progressive Collapse Simulation of Reinforced Concrete Structures: Influence of Desig TAFATNEB 0 1,796 11-23-2013, 01:46 PM
  COMPONENT BASED SEISMIC VULNERABILITY ASSESSMENT PROCEDURE FOR RC BUILDINGS TAFATNEB 0 1,608 11-02-2013, 01:19 PM
