Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis COLLAPSE ASSESSMENT OF CONCRETE BUILDINGS: AN APPLICATION TO NON-DUCTILE REINFORCED C
12-28-2013, 08:59 PM
COLLAPSE ASSESSMENT OF CONCRETE BUILDINGS: AN APPLICATION TO NON-DUCTILE REINFORCED CONCRETE MOMENT FRAMES
Author: Majid Baradaran Shoraka | Size: 9.3 MB | Format: PDF | Quality: Unspecified | Publisher: THE FACULTY OF GRADUATE AND POSTDOCTORAL STUDIES (Civil Engineering) THE UNIVERSITY OF BRITISH COLUMBIA (Vancouver) | Year: august 2013 | pages: 251
[Image: 29009637726334727481.png]
Existing reinforced concrete buildings lacking details for ductile response during earthquake shaking represent prevalent construction type in high seismic zones around the world. Seismic rehabilitation of these existing buildings plays an important role in reducing urban seismic risk; however, with the massive inventory of existing concrete buildings and high costs of seismic rehabilitation, it is necessary to start by identifying and retrofitting those buildings which are most vulnerable to collapse. The collapse of most non-ductile concrete buildings will be controlled by the loss of support for gravity loads prior to the development of a side-sway collapse mechanism. “Gravity load collapse” may be precipitated by axial-load failure of columns, punching-shear failure of
slab-column connections, or axial-load failure beam-column joints. In this dissertation, systemlevel collapse criteria are developed and implemented in a structural analysis platform to allow for a more accurate detection of collapse in these existing moment frames. Detailed models for primary components, which may precipitate gravity-load collapse of the concrete moment frame, are first required to achieve this objective and develop the collapse
assessment framework. An analytical model based on mechanics is developed to reliably capture the lateral load–deformation response of a broad range of reinforced concrete columns with
limited ductility due to degradation of shear resistance, either before or after flexural yielding.
The robust collapse performance assessment could be used for many structural applications. In this dissertation, it is used to identify collapse indicators, design and response
parameters that are correlated with “elevated” collapse probability. The collapse assessment framework is also used to identify the relative collapse risk of different rehabilitation techniques.vFinally, the framework is used to estimate the impact of collapse criteria on the expected financial losses for existing concrete frame buildings in high seismic zones.
  • vardan, malc, techno, Sumatra, blaze, Dell_Brett, cace-01, Rami11
  The Seismic Analysis of Statically Designed Tall Reinforced Concrete Buildings Using bridgeengineer 0 2,938 04-20-2016, 09:31 AM
Last Post: bridgeengineer
  SEISMIC PERFORMANCE ASSESSMENT OF REINFORCED CONCRETE BUILDINGS WITH PRECAST CONCRETE TAFATNEB 0 1,878 03-27-2015, 03:16 PM
  Assessment of Progressive Collapse Requirements for Precast Concrete Buildings TAFATNEB 0 1,829 12-13-2014, 05:08 PM
  SEISMIC DESIGN, TESTING AND ANALYSIS OF REINFORCED CONCRETE WALL BUILDINGS TAFATNEB 0 1,765 05-09-2014, 04:36 PM
  Seismic Performance, Modeling, and Failure Assessment of Reinforced Concrete Shear Wa TAFATNEB 0 1,660 05-09-2014, 04:00 PM
  EVALUATION OF THE SEISMIC PERFORMANCE OF REINFORCED CONCRETE BUILDINGS TAFATNEB 0 1,624 05-09-2014, 11:35 AM
  In Situ Dynamic Characteristics of Reinforced Concrete Shear Wall Buildings mybest 1 2,240 04-08-2014, 10:33 AM
Last Post: Grunf
