Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Non-linear analysis of a collapsed reinforced concrete chimney
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
11-13-2012, 01:13 AM
Author: Wei Huang | Size: 6 MB | Format: PDF | Quality: Scanner | Year: 2005 | pages: 171
During the Ismit (Kocaeli) earthquake of 17 August 1999, a 115m high reinforced concrete chimney or heater stack, located at the Tüpras Refinery, collapsed. The falling debris cut 63 pipes, which contributed to interrupted production for more than 14 months. This stack was designed and constructed according to international standards and is representative of similar structures at refineries throughout the world, including those in earthquake-prone regions. It was distinguished from similar stacks at the site by a much larger rectangular opening for the flue duct, circumscribing a horizontal arc of about 50°. The opening was located about 1/3 of the height above the base and appeared to be the region of initiation of the collapse. The investigation is focused on the dynamic response of the stack due to an earthquake motion recorded at a nearby site. In this paper the results of a response spectrum analysis of the Tüpras stack and a generic U.S. stack are summarized. Then, a non-linear static analysis of the collapsed stack is presented using a demand-collapse comparison. The demand is represented by an acceleration-displacement response spectrum based on the recorded motion as well as some smoothed adaptations typical of design spectra, while the capacities are calculated from pushover curves using a non-linear reinforced concrete finite element analysis. Results are presented that show the effects of the hole and the orientation of the motion with respect to the hole. Also higher-mode contributions to the pushover pattern are considered. The results confirm that the stack could readily fail under the considered earthquake and are also consistent with the debris pattern.
[-] The following 10 users Like mybest's post:10 users Like mybest's post
  • Quantumm, cace-01, Dell_Brett, jjingo, blaze, zrilek, malc, ruaumoko, ykhackhack, louislouis
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,709 in 1,305 posts
Given Likes: 4621
11-06-2020, 08:17 AM
Non-linear analysis of a collapsed reinforced concrete chimney = Paper from:
EARTHQUAKE ENGINEERING AND STRUCTURAL DYNAMICS
Earthquake Engng Struct. Dyn. 2004; 33:485–498 (DOI: 10.1002/eqe.362)
[-] The following 7 users Like lisine's post:7 users Like lisine's post
  • PinkPant, chandra1234567, oanm2000, kowheng, mgdario, sodapas, CAMSECT
  The Seismic Analysis of Statically Designed Tall Reinforced Concrete Buildings Using bridgeengineer 0 2,960 04-20-2016, 09:31 AM
Last Post: bridgeengineer
  Using Non-Linear Vibration Techniques to Detect Damage in Concrete Bridges TAFATNEB 0 1,574 08-08-2014, 01:55 PM
  Design and Analysis of Complex D-Regions in Reinforced Concrete Structures nima_b12 1 2,115 07-21-2014, 01:23 PM
Last Post: apocalipse
  SEISMIC DESIGN, TESTING AND ANALYSIS OF REINFORCED CONCRETE WALL BUILDINGS TAFATNEB 0 1,783 05-09-2014, 04:36 PM
  A FIBER BEAM-COLUMN ELEMENT FOR SEISMIC RESPONSE ANALYSIS OF REINFORCED CONCRETE STRU TAFATNEB 0 1,652 04-12-2014, 02:40 PM
  Analysis and Design of Reinforced Concrete Shell Elements - MSc Thesis asim99 1 2,525 04-04-2014, 02:58 PM
Last Post: Mohammad6299
  A model for the non linear dynamic analysis of reinforced concrete and masonry framed TAFATNEB 0 1,619 04-02-2014, 12:42 PM
