Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis PUSHOVER ANALYSIS OF AN EXISTING REINFORCED CONCRETE STRUCTURE
09-04-2013, 09:03 AM (This post was last modified: 09-04-2013, 01:27 PM by oanm2000.)
Author: Jón Örvar Bjarnason | Size: 1.5 MB | Format: PDF | Quality: Unspecified | Year: 2008 | pages: 103
[Image: 41002202605368352604.png]
The main purpose of this study is to analyze the seismic response of a reinforced concrete structure which suffered damage in the South Iceland earthquakes in June 2000.
Two different methods are used to analyse the structure. First, a 3D linear elastic response spectrum analysis (RSA) is carried out in a finite element program, using response spectra within the European seismic design code (EC8). The response spectrum analysis is followed with a pushover analysis of one of the walls which suffered the most severe damage. A new finite element model is constructed where the nonlinear properties of the reinforced concrete are implemented. The pushover analysis is combined to the response spectra approach through the comprehensive N2 method, which is a novelty in EC8. Results of the pushover analysis are used to estimate the performance of the structure under the design earthquake load. Deformation of the structure, stress strain and evaluation of cracks in the reinforced concrete are reviewed. Damage obtained in the analysis and the actual reported damages are then compared. Finally, the effect of strengthening is estimated.
The study showed that despite serious damage, the structural wall is able to withstand the earthquake design load. However, the structure does by no means meet the design code requirements. Observed damage was fairly consistent with that actually reported, but according to the analysis the N2 procedure tends to be conservative. As shown in the study, the pushover analysis based on the N2 method is a desirable procedure in order to evaluate the seismic resistance of existing structures, especially if there is doubt that response spectrum analysis provides sufficient information.
[-] The following 16 users Like TAFATNEB's post:16 users Like TAFATNEB's post
  • viet2010, maad59, rezart, devilmaycry, vardan, gulilero, ibg0203, blaze, hapsea, ssobhan, malc, kowheng, sodapas, mgdario, Veggeta, learner20
  Non-linear analysis of a collapsed reinforced concrete chimney mybest 1 3,848 11-06-2020, 08:17 AM
  The Seismic Analysis of Statically Designed Tall Reinforced Concrete Buildings Using bridgeengineer 0 2,938 04-20-2016, 09:31 AM
Last Post: bridgeengineer
  Design and Analysis of Complex D-Regions in Reinforced Concrete Structures nima_b12 1 2,100 07-21-2014, 01:23 PM
Last Post: apocalipse
  SEISMIC DESIGN, TESTING AND ANALYSIS OF REINFORCED CONCRETE WALL BUILDINGS TAFATNEB 0 1,765 05-09-2014, 04:36 PM
  A FIBER BEAM-COLUMN ELEMENT FOR SEISMIC RESPONSE ANALYSIS OF REINFORCED CONCRETE STRU TAFATNEB 0 1,636 04-12-2014, 02:40 PM
  APPLICATION OF PUSHOVER ANALYSIS TO RC BRIDGES TAFATNEB 0 1,787 04-11-2014, 09:26 AM
  Analysis and Design of Reinforced Concrete Shell Elements - MSc Thesis asim99 1 2,503 04-04-2014, 02:58 PM
Last Post: Mohammad6299
