Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis SEISMIC ANALYSIS OF MULTISTOREY BUILDING WITH FLOATING COLUMN
08-28-2013, 07:23 PM
Author: Sukumar Behera | Size: 1.2 MB | Format: PDF | Quality: Unspecified | Publisher: Department of Civil Engineering, National Institute of Technology Rourkela- 769008 | Year: may2012 | pages: 93
[Image: 78854295487966757808.png]
In present scenario buildings with floating column is a typical feature in the modern multistory
construction in urban India. Such features are highly undesirable in building built in seismically
active areas. This study highlights the importance of explicitly recognizing the presence of the
floating column in the analysis of building. Alternate measures, involving stiffness balance of the
first storey and the storey above, are proposed to reduce the irregularity introduced by the
floating columns. FEM codes are developed for 2D multi storey frames with and without floating column to study
the responses of the structure under different earthquake excitation having different frequency content keeping the PGA and time duration factor constant. The time history of floor displacement, inter storey drift, base shear, overturning moment are computed for both the
frames with and without floating column.
[-] The following 19 users Like TAFATNEB's post:19 users Like TAFATNEB's post
  • gulilero, maad59, sodapas, ykhackhack, Dell_Brett, malc, kowheng, subin91, tang1942, kirankumarklk, slowet, blaze, ashcivilea, melekeen, learner20, Ivan_1980, hmwere, rezart, mgdario
  Seismic Behaviour of Cable-Stayed Bridges: Design, Analysis and Seismic Devices TAFATNEB 0 1,716 08-31-2014, 07:45 AM
  BEAM - COLUMN CONNECTION FLEXURAL BEHAVIOR AND SEISMIC COLLAPSE PERFORMANCE OF CONCEN TAFATNEB 0 1,641 04-26-2014, 09:52 AM
  An analytical study of reinforced concrete beam-column joint behavior under seismic l TAFATNEB 0 1,660 04-19-2014, 08:58 AM
  A FIBER BEAM-COLUMN ELEMENT FOR SEISMIC RESPONSE ANALYSIS OF REINFORCED CONCRETE STRU TAFATNEB 0 1,599 04-12-2014, 02:40 PM
  BASE ISOLATION FOR MULTISTOREY BUILDING STRUCTURES TAFATNEB 1 1,837 11-20-2013, 06:52 AM
  SEISMIC PERFORMANCE OF MULTI-SPAN RC BRIDGE WITH IRREGULAR COLUMN HEIGHTS TAFATNEB 0 1,620 11-10-2013, 10:04 PM
  Seismic Analysis of a Typical Masonry Building from Barcelona’s Eixample District TAFATNEB 0 1,583 11-02-2013, 11:34 AM
