Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis SEISMIC PERFORMANCE OF MULTI-SPAN RC BRIDGE WITH IRREGULAR COLUMN HEIGHTS
11-10-2013, 10:04 PM
Author: Samy Muhammad Reza | Size: 3.3 MB | Format: PDF | Quality: Unspecified | Publisher: THE UNIVERSITY OF BRITISH COLUMBIA (Okanagan) | Year: 2012
[Image: 29357034418204911371.png]
Bridges are essential elements in modern transportation network and play a significant role
in a country’s economy. However, it has always been a major challenge to keep bridges safe and
serviceable. Modern bridge design codes include seismic detailing in order to ensure ductile
behavior, which was absent in the pre-1970 codes that made older bridges vulnerable during
earthquakes. The main parameters effecting the performance of bridge (tie spacing, concrete and steel properties, amount of reinforcement) varies significantly from old to modern bridges. The presence of irregularity in column heights is one of the common causes of seismic vulnerability and the non-uniform column height is the most common form of irregularity. In this study, a four span RC box-girder bridge has been considered for different column height configurations. Here, a detailed parametric study has been performed to understand the effects of various factors on the limit states of the individual bridge columns using factorial analysis. Static pushover analyses, incremental dynamic analyses and fragility analyses of bridges with irregular column heights have been conducted to identify the seismic vulnerability of bridges in the longitudinal direction due to irregularity in column height. This study also investigated the difference of conventional force-based approach and displacement-based approach in designing a bridge with irregular column heights. Canadian Highway Bridge Design Code (CHBDC) and AASHTO 2007, like other traditional design codes follow force-based design (FBD) method, which is focused at the target force resistance capacity of the structure. On the other hand, displacement-based design approach focuses on a target maximum displacement of the bridge during the earthquake in a
specific zone. Seismic performances of the bridges designed in two different methods have been compared by non-linear dynamic analyses in the longitudinal direction in terms of maximum and residual displacements and energy dissipation capacity.
  • rezart, malc, vardan, blaze, fred2010, engrezi
Users browsing this thread:
  Seismic Performance Assessment and Probabilistic Repair Cost Analysis of Precast Conc TAFATNEB 0 1,588 07-03-2015, 10:30 PM
  Performance Based Approach in Seismic Design of Embedded Retaining Walls TAFATNEB 0 1,928 02-09-2015, 07:24 AM
  Seismic Performance, Modeling, and Failure Assessment of Reinforced Concrete Shear Wa TAFATNEB 0 1,678 05-09-2014, 04:00 PM
  EVALUATION OF THE SEISMIC PERFORMANCE OF REINFORCED CONCRETE BUILDINGS TAFATNEB 0 1,645 05-09-2014, 11:35 AM
  BEAM - COLUMN CONNECTION FLEXURAL BEHAVIOR AND SEISMIC COLLAPSE PERFORMANCE OF CONCEN TAFATNEB 0 1,690 04-26-2014, 09:52 AM
  The Seismic Performance of Coupled Reinforced Concrete Walls TAFATNEB 0 1,713 04-21-2014, 10:59 PM
  An analytical study of reinforced concrete beam-column joint behavior under seismic l TAFATNEB 0 1,707 04-19-2014, 08:58 AM
