Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Improving The Behavior of Special Concentrically Brace Frame w/ Cast Steel Inserts
 asim99
User ID: 9774
Threads: 476
Likes: 6,384 in 594 posts
Given Likes: 377
02-26-2013, 04:59 PM
IMPROVING THE BEHAVIOR OF SPECIAL CONCENTRICALLY BRACE FRAMES WITH CAST STEEL INSERTS
Author: Kristen M. Ward | Size: 6.79 MB | Format: PDF | Quality: Unspecified | Publisher: Kristen M. Ward | Year: 2012 | pages: 147
[Image: 37641654338984394654.jpg]
A Cast Modular Ductile Bracing System (CMDB) has been developed as an alter-
native to special concentrically braced frames. The CMDB system introduces cast
components at the ends and center of the brace in an attempt to produce a system
with reliable strength, sti ness, and deformation capacity. A cruciform cross-section
has been chosen for the cast component geometry, which is specially detailed to en-
hance energy dissipation and increase low cycle fatigue life thereby reducing the
likelihood of fracture. In this dissertaion, capacity design parameters are estab-
lished that describe the axial strength and
exural strength of the cast components
relative to the main hollow structural section member. These parameters are varied
in 2D nite element models to understand the nature of the system and identify the
best performing designs. The cruciform shape of the casting is varied to produce
better performance and self-centering enhancements are introduced. 3D FE models
of the CMDB system and a typical special concentrically braced frame, in combi-
nation with fracture indices, are used to compare the expected low cycle fatigue life
of the two systems. The dynamic performance of the system is assessed through
nonlinear nite element anaylses and conclusions are drawn.
[-] The following 8 users Like asim99's post:8 users Like asim99's post
  • blaze, jcbv, mahyarov, cace-01, malc, carolinandra, kowheng, Dell_Brett
 LiviuM
Christmas Island
User ID: 430
Threads: 90
Likes: 3,228 in 559 posts
Given Likes: 1706
02-27-2013, 11:15 PM
[-] The following 4 users Like LiviuM's post:4 users Like LiviuM's post
  • Dell_Brett, ting tsai huang, warbeast, 3fan
  Advanced Analysis of Steel Frame Structures Subjected to Lateral Torsional Buckling E TAFATNEB 0 1,851 10-06-2014, 10:36 AM
  performance assessment of multistroyed rc special moment resisting frame TAFATNEB 0 1,636 06-03-2014, 07:30 AM
  Performance-Based Seismic Demand Assessment of Concentrically Braced Steel Frame Buil TAFATNEB 0 1,734 05-09-2014, 05:09 PM
  Seismic Response of a Full-scale 5-story Steel Frame Building Isolated by Triple Pend hich 3 2,681 01-27-2013, 09:07 PM
Last Post: hich
  TOWARD ADVANCED ANALYSIS IN STEEL FRAME DESIGN asim99 0 1,600 12-31-2012, 02:30 AM
Last Post: asim99
  Uniaxial and Triaxial Behavior of high strength concrete with and without steel fibe asim99 0 1,572 11-27-2012, 10:32 PM
Last Post: asim99
  BUCKLING BEHAVIOR OF COLD-FORMED STEEL LIPPED CHANNEL IN COMPRESSION niki102 0 1,912 07-20-2011, 06:20 PM
Last Post: niki102
