Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis TOWARD ADVANCED ANALYSIS IN STEEL FRAME DESIGN
 asim99
User ID: 9774
Threads: 476
Likes: 6,384 in 594 posts
Given Likes: 377
12-31-2012, 02:30 AM
Author: Ken Hwa | Size: 9.15 MB | Format: PDF | Quality: Unspecified | Publisher: Ken Hwa | Year: 2003 | pages: 219
[Image: 44402259637527367599.jpg]
The trends for analysis and design of steel frames are indicated in this dissertation. The current practice consists of applying the first-order elastic analysis with amplification factors or second-order elastic analysis in combination with the AISC-LRFD interaction ·
equations. Determination of the effective length factors and individual member capacity checks are necessary to select adequate structural member sizes. The direct analysis method is a second-order elastic analysis approach that eliminates the determination of effective length factors from the current AISC-LRFD method. Unsupported member length is used to calculate the axial strength of a member. Equivalent notional loads
and/or modified stiffuess are applied together with the external loads to account for the effects of initial out-of-plumbness and inelastic softening. For both AISC-LRFD and direct analysis methods, a structure is analyzed as a whole, but the axial and flexural strength of each member is examined individually. Inelastic redistribution of internal forces in the structural system cannot be considered. As a result, determined member forces are not correct and more conservative member sizes will be obtained. Moreover, member-based approaches cannot predict structural behaviors such as failure mode and overstength factor.
[-] The following 7 users Like asim99's post:7 users Like asim99's post
  • cace-01, Dell_Brett, knrsa, malc, ting tsai huang, slowet, hoxuantu
  Advanced Analysis of Steel Frame Structures Subjected to Lateral Torsional Buckling E TAFATNEB 0 1,851 10-06-2014, 10:36 AM
  Performance-Based Seismic Demand Assessment of Concentrically Braced Steel Frame Buil TAFATNEB 0 1,734 05-09-2014, 05:09 PM
  Evaluation Of Pushover Analysis Procedures For Frame Structures abouferass88 2 2,859 08-26-2013, 11:21 PM
  Improving The Behavior of Special Concentrically Brace Frame w/ Cast Steel Inserts asim99 1 1,967 02-27-2013, 11:15 PM
Last Post: LiviuM
  Seismic Response of a Full-scale 5-story Steel Frame Building Isolated by Triple Pend hich 3 2,680 01-27-2013, 09:07 PM
Last Post: hich
  ANALYSIS AND DESIGN OF STEEL DECK – CONCRETE COMPOSITE SLABS - Phd asim99 0 1,840 11-27-2012, 09:52 PM
Last Post: asim99
