Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Multi-criteria decision support framework for optimal multi-hazard design of passivel
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
11-05-2012, 12:34 PM
Multi-criteria decision support framework for optimal multi-hazard design of passively damped structures
Author: Seda Doguel | Size: 3 MB | Format: PDF | Quality: Original preprint | Year: 2011 | pages: 291
[Image: 53888906408570920566.png]
This dissertation develops a new multi-criteria decision support framework for conducting multi-hazard design and retrofit of seismic- and wind-excited structures with passive energy dissipation PED) devices. In addition to designing in compliance with the relevant codes of practice, it is important to note that the performance of PED devices for reducing the structural responses depends on the type, size, and distribution of dampers. The proposed framework provides a genetic algorithm GA) based methodology to address these optimization issues of structural control systems within the context of nonlinear structures. Steel buckling restrained braces, viscous fluid dampers and solid viscoelastic dampers are all considered as possible design alternatives within this framework. In the proposed algorithm, passively damped structural designs evolve toward configurations that limit damage associated with inter-story drift and absolute peak floor acceleration, while considering essential conflicts in dynamic response demands of the structures under different hazard environments, involving earthquakes and strong windstorms. Optimal design of passively damped structures in such uncertain hazardous environments requires not only choosing the most cost-effective approach from a series of alternatives but also defining project-specific constraints and the risk associated with each decision alternative. Thus, unlike previous work in PED optimization, the proposed framework introduces a newly developed multi-objective genetic algorithm to accelerate the convergence to the robust design solutions and to maximize the overall benefit of the structural control system. Additionally, a probability-based optimization approach is introduced to allow decision makers to achieve a specific performance objective, such as identifying the retrofitting investments that will result in minimum life-cycle cost impact on a building. This new approach uses weighted life-cycle cost as an objective function to permit consideration of risk aversion by accounting for uncertainty related to earthquake frequency, structural vulnerability, cost of structural damage and retrofitting, and mitigation benefits. The proposed optimization framework is applied to several example buildings designed or retrofitted with passive control devices to demonstrate the effectiveness of the optimization approaches. From the illustrative examples, it is positively concluded that the modular framework can be successfully used as a practical decision-making tool for cost-effective optimal multiple hazard design of passively damped structures. Also, it is shown that the probability-based optimization approach results in design or retrofit alternatives that combine well with the performance-based design concept, with usage of more realistic design criteria, such as expected life-cycle cost of meeting prescribed performance level.
[-] The following 7 users Like mybest's post:7 users Like mybest's post
  • ykhackhack, david-smith, kowheng, ska51, ssobhan, Dell_Brett, cace-01
  Analytical Studies of The Relations Among Various Design Criteria For Prestressed RyanRS 0 1,588 07-05-2015, 04:26 AM
Last Post: RyanRS
  SEISMIC PERFORMANCE OF MULTI-SPAN RC BRIDGE WITH IRREGULAR COLUMN HEIGHTS TAFATNEB 0 1,662 11-10-2013, 10:04 PM
  MULTI-HAZARD DESIGN OF MID- TO HIGH-RISE STRUCTURES TAFATNEB 0 1,712 09-08-2013, 08:52 PM
  Optimal Conceptual Design of High-Rise Office Buildings asim99 1 2,316 02-27-2013, 11:55 PM
Last Post: LiviuM
  Numerical Analysis and Design Criteria of Embankments on Floating Piles hapsea 0 1,475 10-21-2012, 08:50 AM
Last Post: hapsea
  Multi-scale computational simulation of progressive collapse of steel frames david-smith 2 2,507 06-02-2012, 05:25 PM
Last Post: ssobhan
  Disaggregated Seismic Hazard and the Elastic Input Energy Spectrum: An Approach to Design Earthquake Selection|1998 Administrator 1 1,989 01-29-2012, 08:13 AM
Last Post: joker™
