Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Multi-scale computational simulation of progressive collapse of steel frames
 david-smith
United States
User ID: 43924
Threads: 247
Likes: 4,023 in 582 posts
Given Likes: 1085
06-02-2012, 01:05 PM (This post was last modified: 06-02-2012, 01:44 PM by mybest.)
Author: Kapil Khandelwal | Size: 13 MB | Format: PDF | Quality: Unspecified | Publisher: ProQuest, UMI Dissertation Publishing | Year: 2011 | pages: 310 | ISBN: 124357822X-978-1243578228
[Image: 29878897370621048754.jpg]
Progressive building collapse occurs when failure of a structural component leads to the failure and collapse of surrounding members, possibly promoting additional collapse. Global system collapse will occur if the damaged system is unable to reach a new static equilibrium configuration. The objective of this research is to identify and investigate important issues related to collapse of seismically designed steel building systems using multi-scale computational models. Coupled multi-scale finite element simulations are first carried out to investigate the collapse response of moment resisting steel frame sub-assemblages. Simulation results suggest that for collapse resistant construction, designers should strive to use a larger number of smaller beam members rather than concentrate resistance in a few larger members and should specify ASTM A-992 steel rather than specifying generic steels. Improved behavior can also be achieved by increasing the shear tab thickness or directly welding the beam web to the column. Using information gleaned from the sub-assemblage simulations, computationally efficient structural scale models for progressive collapse analysis of seismically designed steel frames systems are developed. The models are calibrated and utilized within the context of the alternate path method to study the collapse resistance of multistory steel moment and braced frame building systems. A new analysis technique termed "pushdown analysis" is proposed and used to investigate collapse modes, failure loads and robustness of seismically designed frames. The collapse and pushdown analyses show that systems designed for high seismic risk are less vulnerable to gravity-induced progressive collapse and more robust than those designed for moderate seismic risk. Motivated by a number of deficiencies in existing ductile fracture models for steel, a new micro-mechanical constitutive model is proposed. Damage mechanics principles are used and a scalar damage variable is introduced to represent micro-structural evolution related to micro-void nucleation, growth and coalescence during the ductile fracture process in steels. Numerical implementation and parametric studies are presented and discussed. Calibration and validation studies show that the proposed model can successfully represent ductile fracture of steels. Although the system studies in this dissertation focused primarily on in-plane collapse response, the models and simulation methodologies developed herein can be extended in future work to address the collapse resistance of three-dimensional models.
[-] The following 2 users Like david-smith's post:2 users Like david-smith's post
  • warbeast, ykhackhack
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
06-02-2012, 01:43 PM
Here friend
password
[-] The following 9 users Like mybest's post:9 users Like mybest's post
  • warbeast, david-smith, marion33, gulilero, sodapas, ykhackhack, Dell_Brett, kowheng, malc
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
06-02-2012, 05:25 PM
Direct link:
[-] The following 6 users Like ssobhan's post:6 users Like ssobhan's post
  • david-smith, ykhackhack, Dell_Brett, kowheng, slowet, devilmaycry
  Alternate Path method in progressive collapse analysis hich 2 4,285 03-27-2020, 09:58 PM
Last Post: sabooryan
  Assessment of Progressive Collapse Requirements for Precast Concrete Buildings TAFATNEB 0 1,845 12-13-2014, 05:08 PM
  Progressive Collapse Simulation of Reinforced Concrete Structures: Influence of Desig TAFATNEB 0 1,803 11-23-2013, 01:46 PM
  SEISMIC DESIGN OF FRICTION DAMPED BRACED STEEL PLANE FRAMES BY ENERGY METHODS TAFATNEB 0 1,682 08-31-2013, 01:09 PM
  SEISMIC ANALYSIS OF KNEE ELEMENTS FOR STEEL FRAMES TAFATNEB 0 1,554 08-26-2013, 11:43 PM
  PhD Progressive Collapse Comparison of Main Standards LiviuM 1 2,226 04-20-2013, 03:15 AM
Last Post: cace-01
  P-Delta Effects on Steel Moment Frames with Reduced Beam Section Connection asim99 1 1,944 02-27-2013, 11:29 PM
Last Post: LiviuM
