Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Disaggregated Seismic Hazard and the Elastic Input Energy Spectrum: An Approach to Design Earthquake Selection|1998
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 278
Likes: 21,160 in 2,347 posts
Given Likes: 4240
04-21-2009, 06:42 AM (This post was last modified: 01-19-2012, 04:09 PM by Administrator.)
Martin C. Chapman
Thesis submitted to the Faculty of the Virginia Polytechnic Institute and State University in partial
fulfillment of the requirements for the degree of
Doctor of Philosophy in Geophysics
J. Arthur Snoke, Chair
Gilbert A. Bollinger
Edwin S. Robinson
James R. Martin
Mahendra P. Singh
June 25, 1998
Blacksburg, Virginia
Keywords: Seismic Hazard, Strong Motion, Design Earthquakes, Input Energy
(Abstract)
The design earthquake selection problem is fundamentally probabilistic. Disaggregation of a probabilistic model of the seismic hazard offers a rational and objective approach that can identify the most likely earthquake scenario(s) contributing to hazard. An ensemble of time series can be selected on the basis of the modal earthquakes derived from the disaggregation. This gives a useful time-domain realization of the seismic hazard, to the extent that a single motion parameter captures the important time-domain characteristics. A possible limitation to this approach arises because most currently available motion prediction models for peak ground motion or oscillator response are essentially independent of duration, and modal events derived using the peak motions for the analysis may not represent the optimal characterization of the hazard.
The elastic input energy spectrum is an alternative to the elastic response spectrum for these types of analyses. The input energy combines the elements of amplitude and duration into a single parameter description of the ground motion that can be readily incorporated into standard probabilistic seismic hazard analysis methodology. This use of the elastic input energy spectrum is examined. Regression analysis is performed using strong motion data from Western North America and consistent data processing procedures for both the absolute input energy equivalent
velocity, (Vea), and the elastic pseudo-relative velocity response (PSV) in the frequency range 0.5 to 10 Hz. The results show that the two parameters can be successfully fit with identical functional forms. The dependence of Vea and PSV upon (NEHRP) site classification is virtually identical. The variance of Vea is uniformly less than that of PSV, indicating that Vea can be predicted with slightly less uncertainty as a function of magnitude, distance and site classification. The effects of site class are important at frequencies less than a few Hertz. The regression modeling does not resolve significant effects due to site class at frequencies greater than approximately 5 Hz.
Disaggregation of general seismic hazard models using Vea indicates that the modal magnitudes for the higher frequency oscillators tend to be larger, and vary less with oscillator frequency, than those derived using PSV. Insofar as the elastic input energy may be a better parameter for
quantifying the damage potential of ground motion, its use in probabilistic seismic hazard analysis could provide an improved means for selecting earthquake scenarios and establishing design earthquakes for many types of engineering analyses.
[-] The following 16 users Like Administrator 's post:16 users Like Administrator 's post
  • kamran, kamran, aslam, aslam, akovali85, akovali85, lucky_b2me, lucky_b2me, golpesar, golpesar, niki102, niki102, arceon, malc, sodapas, sructme
Away  joker™
User ID: 10925
Threads: 92
Likes: 7,246 in 938 posts
Given Likes: 2426
01-29-2012, 08:13 AM
No limits to creativity
  Performance Based Approach in Seismic Design of Embedded Retaining Walls TAFATNEB 0 1,928 02-09-2015, 07:24 AM
  Friction-based Control System for Seismic Energy Dissipation with Isolated Stories TAFATNEB 0 1,517 11-19-2013, 11:05 PM
  MULTI-HAZARD DESIGN OF MID- TO HIGH-RISE STRUCTURES TAFATNEB 0 1,714 09-08-2013, 08:52 PM
  SEISMIC DESIGN OF FRICTION DAMPED BRACED STEEL PLANE FRAMES BY ENERGY METHODS TAFATNEB 0 1,686 08-31-2013, 01:09 PM
  DECISION TREE BASED SEISMIC RETROFIT SELECTION FOR NON-CODE CONFORMING REINFORCED CON TAFATNEB 0 1,498 08-25-2013, 01:43 PM
  Multi-criteria decision support framework for optimal multi-hazard design of passivel mybest 0 1,651 11-05-2012, 12:34 PM
Last Post: mybest
