Civil Engineering Association eBooks Codes, Manual & Handbook AS 1012.12-1998 Methods of testing concrete - Determination of mass per unit volum
03-30-2011, 04:45 AM (This post was last modified: 03-30-2011, 04:50 AM by ir_71.)
AS 1012.12.1-1998 Methods of testing concrete - Determination of mass per unit volume of hardened concrete - Rapid measuring method
Author: Standards Australia | Size: 2.5 MB | Format: PDF | Publisher: Committee BD-042 | Year: 1998 | pages: 3 | ISBN: 0733721567
[Image: 62266335344781745594.jpg]
This Standard sets out a rapid method for determining the mass per unit volume of hardened concrete consisting of regular shaped specimens with a minimum of defects. This Method is also applicable to capped specimens, provided the mass per unit volume of the cap does not differ from that of the specimen by more than 25 percent.
NOTES:
1 Because of possible variation in results, it is envisaged that the mass per unit volume of concrete should be based on the average value determined from a group of at least two representative specimens.
2 For general procedures and precautions designed to promote safety of persons and property in laboratory operations (see AS/NZS 2243.1 - list in Referenced Documents).
3 This Standard may involve hazardous materials, operations, and equipment. This Standard does not purport to address all of the safety problems associated with its use. It is the responsibility of the user of this Standard to establish appropriate safety and health practices and determine the applicability of regulatory limitations prior to use.
AS 1012.12.2-1998 Methods of testing concrete - Determination of mass per unit volume of hardened concrete - Water displacement method
Author: Standards Australia | Size: 2.6 MB | Format: PDF | Publisher: Committee BD-042 | Year: 1998 | pages: 3 | ISBN: 0733721575
[Image: 90286729228877569739.jpg]
This Standard sets out a method for determining the mass per unit volume of hardened concrete by a method involving weighing the specimen in a specified moisture condition and determining its volume by weighing the saturated specimen in water and also in air. This Method is applicable to either regular or irregular shaped specimens. This Method is also applicable to capped specimens, provided the mass per unit volume of the cap does not differ from that of the specimen by more than 25 percent and the cap complies with the requirements of AS 1012.9.
NOTES:
1 Care should be taken to ensure that specimens are representative of the concrete mass, particularly if irregular shaped pieces of concrete are tested. If specimens have a volume less than a 100 + 200 mm standard cylinder, the results may not be as reliable.
2 Where appropriate, surface voids should be sealed or wrapped to ensure account is taken of their effect, e.g. poor compaction.
3 For general procedures and precautions designed to promote safety of persons and property in laboratory operations (see AS/NZS 2243.1 ).
4 This standard may involve hazardous materials, operations, and equipment. This standard does not purport to address all of the safety problems associated with its use. It is the responsibility of the user of this standard to establish appropriate safety and health practices and determine the applicability of regulatory limitations prior to use.
  • kowheng, Grunf, oanm2000, Dell_Brett, melkat, sivlad
  AS 1012.13-1992 Methods of testing concrete - Determination of the drying shrinkage ir_71 1 3,033 10-01-2018, 11:02 AM
  AS 1012.2-1994 Methods of testing concrete - Preparation of concrete mixes in the la ir_71 1 2,288 06-03-2014, 04:09 AM
  PD CEN/TR 196-4:2007 Methods of testing cement mybest 0 1,683 12-03-2011, 06:46 AM
Last Post: mybest
  AS 1012.21-1999 Methods of testing concrete - Determination of water absorption and ir_71 0 1,924 04-01-2011, 05:56 AM
  AS 1012.20-1992 Methods of testing concrete - Determination of chloride and sulfate ir_71 0 1,789 04-01-2011, 05:49 AM
  AS 1012.19-2000 Methods of testing concrete - Accelerated curing of concrete comp ir_71 0 1,679 04-01-2011, 05:39 AM
  AS 1012.18-1996 Methods of testing concrete - Determination of setting time of fres ir_71 0 1,658 04-01-2011, 05:32 AM
