Civil Engineering Association eBooks Codes, Manual & Handbook AS 1012.20-1992 Methods of testing concrete - Determination of chloride and sulfate
04-01-2011, 05:49 AM
AS 1012.20-1992 Methods of testing concrete - Determination of chloride and sulfate in hardened concrete and concrete aggregates
Author: Committee BD-042 | Size: 3.5 MB | Format: PDF | Publisher: Standards Australia | Year: 1992 | pages: 4 | ISBN: 0726273791
[Image: 33731288608345276822.jpg]
This Standard sets out a method for the determination of chloride content and sulfate content (including easily oxidizable sulfide content) of concrete and concrete aggregates. The solutions obtained from the sample may also be used to determine the acidsoluble calcium oxide content of these materials. The method of solution will react with and dissolve any easily oxidizable sulfides which are present and these will be reported as sulfate. Such sulfides have been shown to be deleterious to concrete and the method provides an approach to limiting their inclusion in concrete and concrete aggregates. For compliance with the relevant requirements specified in AS 3600, additional tests and calculations may be required.
NOTES:
Separate test methods are available for the analysis of the other concretemaking materials, e.g. cementious materials, admixtures, water.
Gross variations in the chloride and sulfate contents of concrete and concretemaking materials can occur over distances of even a few millimetres. This can be caused, for example, by leaching with rainwater, surface evaporation and crusting and penetration of salt and ground waters. Sampling technique is of prime importance. As the effect of the use of water during coring, especially small diameter cores, can be significant, the amount of water used should be restricted.
[-] The following 3 users Like ir_71's post:3 users Like ir_71's post
  • kowheng, miquan, sivlad
  AS 1012.13-1992 Methods of testing concrete - Determination of the drying shrinkage ir_71 1 3,082 10-01-2018, 11:02 AM
  AS 1012.2-1994 Methods of testing concrete - Preparation of concrete mixes in the la ir_71 1 2,330 06-03-2014, 04:09 AM
  DD ENV 1992-4:2000, Eurocode 2: Design of concrete structures - Part 4 Mohammad6299 0 1,907 04-20-2014, 10:33 AM
Last Post: Mohammad6299
  PD CEN/TR 196-4:2007 Methods of testing cement mybest 0 1,722 12-03-2011, 06:46 AM
Last Post: mybest
  AS 1012.21-1999 Methods of testing concrete - Determination of water absorption and ir_71 0 1,962 04-01-2011, 05:56 AM
  AS 1012.19-2000 Methods of testing concrete - Accelerated curing of concrete comp ir_71 0 1,721 04-01-2011, 05:39 AM
  AS 1012.18-1996 Methods of testing concrete - Determination of setting time of fres ir_71 0 1,694 04-01-2011, 05:32 AM
