Civil Engineering Association eBooks Codes, Manual & Handbook AS 1012.21-1999 Methods of testing concrete - Determination of water absorption and
04-01-2011, 05:56 AM (This post was last modified: 04-01-2011, 05:59 AM by ir_71.)
AS 1012.21-1999 Methods of testing concrete - Determination of water absorption and apparent volume of permeable voids in hardened concrete
Author: Committee BD-042 | Size: 6.1 MB | Format: PDF | Publisher: Standards Australia | Year: 1999 | pages: 5 | ISBN: 0733728235
[Image: 54638095813512804763.jpg]
This Standard sets out the procedure for determining the immersed absorption (Ai) and, if required, boiled absorption (Ab) and apparent volume of permeable voids (AVPV) in hardened concrete. The drying operation in this test may withdraw the free water that is mechanically held in concrete, and some of the water from the colloidal cementitious gel. The absorptions indicated by the test are larger than those associated with the normal temperature and humidity environment of concrete in service. This method is not intended for use as an absolute measure of durability.
NOTES:
1 Test results obtained by this procedure will be affected by a number of factors including compaction, curing, absorption, age, air entrainment, absorption and vesicular nature of the aggregate and whether the specimen is moulded, is cut from an existing structure or is a piece of irregularly shaped concrete. Test results may also be affected if concrete specimens are carbonated.
2 This Standard may involve the use of hazardous materials and equipment, and engagement in hazardous operations. This Standard does not purport to address all of the safety problems associated with its use. It is the responsibility of the user of this Standard to establish appropriate safety and health practices and to determine the applicability of regulatory limitations prior to use.
This is the last standard from standard series AS 1012, requested by our member coolestbliss.
[-] The following 2 users Like ir_71's post:2 users Like ir_71's post
  • kowheng, sivlad
  AS 1012.13-1992 Methods of testing concrete - Determination of the drying shrinkage ir_71 1 3,082 10-01-2018, 11:02 AM
  AS 1012.2-1994 Methods of testing concrete - Preparation of concrete mixes in the la ir_71 1 2,330 06-03-2014, 04:09 AM
  PD CEN/TR 196-4:2007 Methods of testing cement mybest 0 1,722 12-03-2011, 06:46 AM
Last Post: mybest
  AS 1012.20-1992 Methods of testing concrete - Determination of chloride and sulfate ir_71 0 1,835 04-01-2011, 05:49 AM
  AS 1012.19-2000 Methods of testing concrete - Accelerated curing of concrete comp ir_71 0 1,722 04-01-2011, 05:39 AM
  AS 1012.18-1996 Methods of testing concrete - Determination of setting time of fres ir_71 0 1,694 04-01-2011, 05:32 AM
  AS 1012.17-1997 Methods of testing concrete - Determination of the static chord mod ir_71 0 1,755 04-01-2011, 05:25 AM
