Civil Engineering Association eBooks Codes, Manual & Handbook AS 1012.6-1999 Methods of testing concrete - Method for the determination of bleedin
03-29-2011, 05:23 AM
AS 1012.6-1999 Methods of testing concrete - Method for the determination of bleeding of concrete
Author: Committee BD-042 | Size: 4.8 MB | Format: PDF | Publisher: Standards Australia | Year: 1999 | pages: 6 | ISBN: 0733728006
[Image: 71695936695470716783.jpg]
This Standard sets out the method for determining the relative quantity of mixing water that will bleed from a sample of freshly mixed concrete under the conditions of the test. The Standard applies only to concrete in which the maximum aggregate size is 40 mm or less.
The Standard provides for compaction of the sample either by rodding or vibrating.
NOTES:
1 The results obtained will be dependent on the compaction method used.
2 This Standard may involve hazardous materials, operations, and equipment. The Standard does not purport to address all of the safety problems associated with its use. The user of this Standard should establish appropriate safety and health practices and determine the applicability of regulatory limitations prior to use.
3 Data on the precision of the test method were not available at the time of publication. This information will be included when available.
[-] The following 3 users Like ir_71's post:3 users Like ir_71's post
  • kowheng, super_engineer, sivlad
  AS 1012.13-1992 Methods of testing concrete - Determination of the drying shrinkage ir_71 1 3,082 10-01-2018, 11:02 AM
  AS 1012.2-1994 Methods of testing concrete - Preparation of concrete mixes in the la ir_71 1 2,330 06-03-2014, 04:09 AM
  PD CEN/TR 196-4:2007 Methods of testing cement mybest 0 1,722 12-03-2011, 06:46 AM
Last Post: mybest
  AS 1012.21-1999 Methods of testing concrete - Determination of water absorption and ir_71 0 1,963 04-01-2011, 05:56 AM
  AS 1012.20-1992 Methods of testing concrete - Determination of chloride and sulfate ir_71 0 1,835 04-01-2011, 05:49 AM
  AS 1012.19-2000 Methods of testing concrete - Accelerated curing of concrete comp ir_71 0 1,722 04-01-2011, 05:39 AM
  AS 1012.18-1996 Methods of testing concrete - Determination of setting time of fres ir_71 0 1,694 04-01-2011, 05:32 AM
