Civil Engineering Association eBooks Codes, Manual & Handbook AS 1012.4-1999 Methods of testing concrete - Determination of air content of freshly
03-28-2011, 06:55 PM (This post was last modified: 03-28-2011, 07:14 PM by ir_71.)
AS 1012.4-1999 Methods of testing concrete - Determination of air content of freshly mixed concrete
Author: Committee BD-042 | Size: 10.8 MB | Format: PDF | Publisher: Standards Australia | Year: 1999 | pages: 11 | ISBN: 0733727980
[Image: 65662510674131840296.jpg]
This Standard sets out the method for determining the air content of freshly mixed concrete from observations of the change in volume of the concrete when it is subjected to an increased air pressure (see Note 1). The method provides for compaction of the sample either by rodding or by vibration (see Note 2).
NOTES:
1 This method is intended for use with concretes made with relatively dense natural aggregates for which the aggregate correction factor can be determined satisfactorily by the technique described in Clause 10. It is not recommended for use with concretes made with lightweight aggregates, or aggregates of high porosity (see AS 1012.4.3).
2 The results obtained will be dependent on the compaction method used.
3 This Standard may involve hazardous materials, operations, and equipment. The Standard does not purport to address all of the safety problems associated with its use. The user of this Standard should establish appropriate safety and health practices and determine the applicability of regulatory limitations prior to use.
4 Data on the precision of the test method were not available at the time of publication. This information will be included when available.
Author: Committee BD-042 | Size: 6.6 MB | Format: PDF | Publisher: Standards Australia | Year: 1999 | pages: 7 | ISBN: 0733727972
[Image: 20041740354129353536.jpg]
This Standard sets out the method for determining the air content of freshly mixed concrete from observations of the reduction in air pressure in a chamber above the concrete when the concrete is exposed to the air pressure.
NOTES:
1 This method is intended for use with concretes made with relatively dense natural aggregates for which the aggregate correction factor can be determined satisfactorily by the technique described in Clause 9. It is not recommended for use with concretes made with lightweight aggregates, or aggregates of high porosity (see AS 1012.4.3).
Author: Committee BD-042 | Size: 3.2 MB | Format: PDF | Publisher: Standards Australia | Year: 1999 | pages: 6 | ISBN: 0733728073
[Image: 56551386075985729813.jpg]
This Standard sets out the method for determining the air content of freshly mixed concrete using the volumetric method.
This Standard is suitable for concrete made with any type of aggregate, whether it be dense, cellular or lightweight.
NOTES:
1 This Standard may involve hazardous materials, operations, and equipment. The Standard does not purport to address all of the safety problems associated with its use. The user of this Standard should establish appropriate safety and health practices and determine the applicability of regulatory limitations prior to use.
2 Data on the precision of the test method were not available at the time of publication. This information will be included when available.
[-] The following 2 users Like ir_71's post:2 users Like ir_71's post
  • zrilek, sivlad
  AS 1012.13-1992 Methods of testing concrete - Determination of the drying shrinkage ir_71 1 3,087 10-01-2018, 11:02 AM
  AS 1012.2-1994 Methods of testing concrete - Preparation of concrete mixes in the la ir_71 1 2,335 06-03-2014, 04:09 AM
  PD CEN/TR 196-4:2007 Methods of testing cement mybest 0 1,729 12-03-2011, 06:46 AM
Last Post: mybest
  AS 1012.21-1999 Methods of testing concrete - Determination of water absorption and ir_71 0 1,969 04-01-2011, 05:56 AM
  AS 1012.20-1992 Methods of testing concrete - Determination of chloride and sulfate ir_71 0 1,838 04-01-2011, 05:49 AM
  AS 1012.19-2000 Methods of testing concrete - Accelerated curing of concrete comp ir_71 0 1,733 04-01-2011, 05:39 AM
  AS 1012.18-1996 Methods of testing concrete - Determination of setting time of fres ir_71 0 1,704 04-01-2011, 05:32 AM
